Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 5:52 pm)
there are a few ways to do that one is in editing after the fact, the second is by making the figure fully transparent, alot of work there. If you have a good editing software I would go with the first.
Poserverse The New Home
for NYGUY's Freebies
In that case, then, open the material panel and enable the "Animateable" option at the bottom for each material you wish to animate. Afterward, any changes you make to the transparency settings for a given keyframe will be remembered. You can also animate texture, reflection, and bump map strength, the colours, and highlight size.
I am animating my poser scene but during the scene I want a character to disappear only to reappear in a different spot how do you do that with poser 4?
