Wed, Jan 29, 6:58 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 5:52 pm)
Subject: Movie question?
SVicious ( ) posted Sun, 05 October 2003 at 8:37 PM ยท edited Tue, 28 January 2025 at 7:17 AM
I am animating my poser scene but during the scene I want a character to disappear only to reappear in a different spot how do you do that with poser 4?
nyguy ( ) posted Sun, 05 October 2003 at 8:45 PM
there are a few ways to do that one is in editing after the fact, the second is by making the figure fully transparent, alot of work there. If you have a good editing software I would go with the first.
Poserverse The New Home for NYGUY's Freebies
Little_Dragon ( ) posted Sun, 05 October 2003 at 8:53 PM
You can scale the character down from 100% to almost zero, move the reduced figure to a new location, and then scale it back to full size.
Or simply move it quickly out of camera view, and then back again at the new spot.
SVicious ( ) posted Sun, 05 October 2003 at 9:03 PM
tried the transparent trick but the problem i face there is he is transparent in the other frames as well? is there a way i can make him completely transparent for certain frames and not transparent in the other frames?
Little_Dragon ( ) posted Sun, 05 October 2003 at 9:34 PM
Only in Pro Pack and P5. P4, on its own, doesn't support animated materials.
SVicious ( ) posted Sun, 05 October 2003 at 9:41 PM
I have pro pack with poser 4
Little_Dragon ( ) posted Sun, 05 October 2003 at 10:41 PM
In that case, then, open the material panel and enable the "Animateable" option at the bottom for each material you wish to animate. Afterward, any changes you make to the transparency settings for a given keyframe will be remembered. You can also animate texture, reflection, and bump map strength, the colours, and highlight size.
SVicious ( ) posted Sun, 05 October 2003 at 10:42 PM
thank little dragon i'll give that a shot
SVicious ( ) posted Thu, 09 October 2003 at 10:24 PM
Little Dragon I tried that and I got the same result above the character is transparent in every frame do i need to make a transparency map for the material menu or just fiddle around with the dials? Or is it something else?
