Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Attached Link: http://groups.yahoo.com/group/TBKoen/
I find that the link in the second item is to Renderosity. I suspect that you want the included one instead. You'll have to join Yahoo Groups to be able to get at it.And the .EXE inside the .ZIP is infected with a Trojan virus. NAV could not repair the infected file, either.
As the installer is running, it asks for agreement to a license for some sort of player. I suspect that the player contains spyware, but I don't have a spare system here to allow it to install.
You do not appear to need to accept the license (and install the player) to have it unpack the files.
LawnDartLawnDart, have you run Ad-Aware on the system on which you ran the installer? (Did you accept the player?)
Turn off your AV when installing, and immediately turn it back on after. The virus warning springs up because during install of the Predator files, an .exe file gets run at the same time. This .exe file is not a virus but a little animation of the predator. I have had this file on my computer for years and am not infected. I virus scan regularly, update my virus scanner every day, and run ad-aware daily. There is no virus in it. Scan your system after and the only warning should be the original zip file (like you get anyway).
Attached Link: http://www.computing.net/windows95/wwwboard/forum/147399.html
ok I did that and it left a program running in my machine's memory called wowexec.exe (with a space at the begining) after a little research online I have found out that it is in fact spy/adware (without the space at the begining its a normal windows process file) read post 6 at this siteAttached Link: http://www.winnetmag.com/Articles/Index.cfm?ArticleID=3022
wowexec.com is not a trojan or spyware its part of windows. Its used for running 16 bit apps. I have the TBK Predator and it is virus free...I was in the middle of this whole problem years ago when it first happenned... TBKoen used an installer that freaked out Anti Virus apps. I had even gone to lengths at that time to create a 2nd version of the Pred. that didnt use his installer. The file was perfectly safe then, allbeit silly that he used that format to distribute the file. Do a search for the same topic in this forum, you'll find lot's of reading material. Doug
I came, I rendered, I'm still broke.
Attached Link: http://www.answersthatwork.com/Tasklist_pages/tasklist.htm
Just an FYI - This is a very good resource page if you're ever wondering what those programs on your tasklist are, and what exactly would be the best thing to do with them. I thnk that 'wow' stands for 'Windows on windows' and is started by 32 bit versions of windows when it is asked to load a 16 bit program. I'm unfamiliar with the version that has a spacing or _ in the name, thanks for posting about that!Attached Link: http://www.answersthatwork.com/Downright_pages/downrights_a-z.htm
Another wonderful tool on the page Suede refered to: THE Rename 2.1.5 Now I can rename those PZ2 Mat files to CM2 all at once!!! Thanks Suede!This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
looking for TBKoen's preditor model, Anyone know where to find it ?
