Sat, Nov 23, 7:10 PM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
Subject: Signature
Marit ( ) posted Wed, 08 October 2003 at 3:49 AM · edited Sat, 23 November 2024 at 6:47 PM
Hello! This might be a stupid question, don't know.. But how do you guys make a signature on your works?
CavalierLady ( ) posted Wed, 08 October 2003 at 6:05 AM
It is most often done with whichever graphics program you use to finish your image with, such as photoshop, which a lot of artists use. You could even use "paint" on your computer for this. Use the text part of the program to add a name and then save as a part of the image, when you save it as a jpeg. Hope this helps. :)Cav
undisclosed-designer ( ) posted Sun, 12 October 2003 at 2:54 AM
in the charactermap, you can get the which you copy and paste into your text, then your name ... insert it into a visible place in your drawing, then select all (layers), flatten selection, and export it as a .jpg or .gif file or make an unique logo with your name in it somewhere, if you have any other questions, i'll be glad to answer them ... greetings, harmen
marcusbacus ( ) posted Wed, 15 October 2003 at 12:51 PM
In Photoshop, make a text layer over your image with the desired signature text, add an embossing effect on the layer as you wish, and set this layer opacity to "Hard light". This should give you a transparent embossed layer with your text over the image.
Marit ( ) posted Thu, 16 October 2003 at 8:36 AM
Thank you all for your replies! I will give it a try soon and I'm sure I will get it done with your advice!
