Wed, Jan 29, 12:11 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 5:46 am)
Subject: the ultimate user interface???
Zarabanda ( ) posted Wed, 15 October 2003 at 1:40 AM · edited Tue, 28 January 2025 at 7:52 PM
I know this has been posted on before, but does anyone have a ui setup similiar to this?
lmckenzie ( ) posted Wed, 15 October 2003 at 3:23 AM
Mine (poser 4) is pretty much identical except for orienting the tools vertically (alt-left click on the title) and hiding the display style tools which I never use . I don't know if it's "ultimate," but it maximizes the size of the document window. If the space hogging camera and light tools could pop up in floating windows that would be ideal.
narcissus ( ) posted Wed, 15 October 2003 at 3:48 AM
lmckenzie how did you put your editing tools vertical?Mine is always horisontal.
PheonixRising ( ) posted Wed, 15 October 2003 at 5:27 AM
This is what I use. windom 760 by 680. I just open and close libary as I need it. Anton
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
ziggie ( ) posted Wed, 15 October 2003 at 5:57 AM
746 x 663 window
"You don't have to be mad to use Poser... but it helps"
lindans ( ) posted Wed, 15 October 2003 at 6:21 AM
What size monitor and resolution are you all using? I have a 17" monitor and find that I have to set the resolution to 1024 by 768 to get everything in comforatbly but it does make all the tools quite small an my eyesight isn't what it was LOL!
Oh, let the sun beat down upon my face. I am a traveler of both time and space ....Kashmir, Led Zeppelin
ziggie ( ) posted Wed, 15 October 2003 at 6:43 AM
lindans: same setup... 17" 1024x768. I have to wear glasses but find it quite comfortable to work at this resolution.
Dave ( ) posted Wed, 15 October 2003 at 7:11 AM
I do you get the typically horizontal tool bars to be vertical,and vice-versa? Dave
Dave ( ) posted Wed, 15 October 2003 at 7:12 AM
Uh.. that should've been "how" instead of "I". Guess I shouldnt post before I've had my 2nd cup of caffeine. Dave
lindans ( ) posted Wed, 15 October 2003 at 7:13 AM
Thanks ziggie and thanks to Imckenzie for letting me know how to orientate the tools..............you can always find out something new here!!!
lindans ( ) posted Wed, 15 October 2003 at 7:15 AM
Dave.... apparently its ALT and left click on the tool name. Linda
egaeus ( ) posted Wed, 15 October 2003 at 7:19 AM
How do you get the interface to stay that way in Poser 4? I try setting a preferred state, but it doesn't keep the arrangement I set up. Mike
PheonixRising ( ) posted Wed, 15 October 2003 at 7:31 AM
You have to make sure you check "launch to preferred state" and "use Previous State". Also click a memory dot into the UI dots.
Dave-So ( ) posted Wed, 15 October 2003 at 7:40 AM
I had a thread a day or two ago about the same thing in P5...but if you move anything above the tabs, they get locked up there...can't move them, can't use them... Was trying to vertical the toolbars, but forgot how...thanks for that reminder :)
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
Eowyn ( ) posted Wed, 15 October 2003 at 7:57 AM
Here's mine :) 800 x 800 window. Nice and clean, everything fits in there well :)
PheonixRising ( ) posted Wed, 15 October 2003 at 8:35 AM
I like your set yp Eowyn
lindans ( ) posted Wed, 15 October 2003 at 8:59 AM
Another question while we are at it..Is there a way to remove a tab, for instance the Content tab in the pose room, it just takes up space??
PheonixRising ( ) posted Wed, 15 October 2003 at 9:03 AM
tabs are hard coded. You are stuck with em I believe
lindans ( ) posted Wed, 15 October 2003 at 9:14 AM
Can you hide them then???
elgyfu ( ) posted Wed, 15 October 2003 at 9:32 AM
I also save the set-up with whatever character I am mainly working on in the window so that they are already for when I come back! If I am not really using just one character then I save with an empty window which makes Poser open really quickly!
PheonixRising ( ) posted Wed, 15 October 2003 at 9:33 AM
not that I know of
Bobbie_Boucher ( ) posted Wed, 15 October 2003 at 9:42 AM
I have Poser start with a blank document window. I'm using 1152X864 resolution with a 17" monitor. The document window size is 700x600. That seems to be the best I can do.
egaeus ( ) posted Wed, 15 October 2003 at 10:07 AM
<<You have to make sure you check "launch to preferred state" and "use Previous State". Also click a memory dot into the UI dots>> Everything was checked, and I used a memeory dot, and still nothing. The window is the size I want, but the set up goes back to the original. Mike
PandaPride ( ) posted Wed, 15 October 2003 at 10:23 AM
I dont know how to set it up so it stays a certain way but if anyone has any input on how please let me know. I am working with P5, and on the pose room screen the "camera controlls and the tools don't show up. I have to click on the materials room to use these tools. --Essie
egaeus ( ) posted Wed, 15 October 2003 at 10:25 AM
Okay. I got it to work now. Thanks Anton. Mike
CrystalDragon ( ) posted Wed, 15 October 2003 at 10:38 AM
Actually, the tabs are specified in xml. To remove them, see here:
http://www.thenetherworks.com/Tutorial/P5-NoParadise.pdf
BTW, this was discussed over at poserpros.
CrystalDragon ( ) posted Wed, 15 October 2003 at 11:02 AM
Such fun! ^__^
Here's mine. (1280x1024 on a 19")
Zarabanda ( ) posted Wed, 15 October 2003 at 12:36 PM
Im able to set my document window to 825x825, with a 19" monitor and 1280x960 res. Setting a UI dot is a must. P4, especially propack, has a funny way of making slight adjustments to the ui.
JVRenderer ( ) posted Wed, 15 October 2003 at 1:23 PM
I have two monitors. This is how I setup my Poserpropack work space. Total screen resolutions: 2048X768. My document window size depend from project to project. I moved all my tools to the left (15" LCD) and keep the document window on the Right (19" LCD).
Software: Daz Studio 4.15,  Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM,  RTX 3090 .
My Gallery  My Other Gallery
Mason ( ) posted Wed, 15 October 2003 at 2:07 PM
Now this is the ultimate user interface.
Spanki ( ) posted Wed, 15 October 2003 at 2:07 PM
With a 1600x1200 desktop (21" monitor), I've got lots of room to spare. Doc window shown here is at 1000x800. I like Ziggi's and Anton's setups for smaller sizes.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
JVRenderer ( ) posted Wed, 15 October 2003 at 2:22 PM
oops, corrections up there: The doc window is on the left, the tools are one the right. I need coffee :P LOL, I like Mason's
Lyrra ( ) posted Wed, 15 October 2003 at 2:29 PM
Eowyn, hey ... we use the same setup :) I was starting to wonder if there were any other 'lefties'
Spanki ( ) posted Wed, 15 October 2003 at 2:34 PM
I'm left-handed (I'm betting there's a higher percentage than usual of us here), but I grew up in a right-handed world and/so the mouse is in my right hand, so it makes more sense to me to keep all the tools on the right. ~shrug~
maclean ( ) posted Wed, 15 October 2003 at 2:34 PM
Here's mine. 1152 x 864/17" monitor. With and without Hier editor and Joint editor. The 2 editors and the param dials are more useful to me than anything else in the poser UI. No tools, dots or display stytle. I have them alt-clicked and closed in the bottom-left corner. The first thing I do when I open poser is hit 'T' to get the Move tool. But I never use it - I use the dials for everything. The move shape just happens to be the least offensixe-looking of all the tools. I'd really prefer a crosshair cursor. Not to mention a 'minimize' option for all editors. mac
Kelderek ( ) posted Wed, 15 October 2003 at 2:59 PM
Here is mine, on a 1280 x 960 19" monitor. Not very drastic changes from the original, but it works pretty well.
lmckenzie ( ) posted Wed, 15 October 2003 at 4:14 PM
OK, it's been a while since anyone showed the good old clean and lean Poser 2 interface. For those who don't know, type PO2 to get it and PO3 to return to eyecandy :-) BTW I made a small discovery. A while back I was using a utility to look at the Windows attributes of Poser and saw that drag and drop is enabled for the document window. Dropping various files only loaded the factory default casual man. I just tried it with a .pz3 and voila it loads! Not terribly useful but new to me.
PJF ( ) posted Wed, 15 October 2003 at 7:13 PM
Bloody hell, I use virtually the same setup as Eowyn. Yet, strangely, the Poser work doesn't come out the same... ;-)
jerr3d ( ) posted Wed, 15 October 2003 at 7:57 PM
It's very interesting to see other's Poser screen setups. Here's mine. Pardon my trickery!
macmullin ( ) posted Wed, 15 October 2003 at 10:08 PM
This how I set mine up. I would like in the future to have duel monitors.
Norbert ( ) posted Thu, 16 October 2003 at 12:40 AM
So they can shoot each other?
macmullin ( ) posted Thu, 16 October 2003 at 3:34 AM
lol
Silke ( ) posted Thu, 16 October 2003 at 6:39 AM
Ok dumb question......... How do you do that? I'd love to change mine but I don't know how lol
Silke
Kelderek ( ) posted Thu, 16 October 2003 at 8:55 AM
Silke, you mean just to move the different things around? Just grab them with the mouse and move them. As easy as that. Then you can make sure that Poser loads it this way next time by going into "General Preferences" and set this as "preferred state". Also make sure that Poser loads to "preferred state" in the preferences, otherwise it changes back to the factory state next time. To change orientation of the rows with tool buttons, do ALT-left click on the title.
lesbentley ( ) posted Thu, 16 October 2003 at 6:28 PM
Here is my UI layout in Poser 4. 21 inch monitor at 1024x768 resolution. The Document Window Size in this picture is 765x621.
lesbentley ( ) posted Thu, 16 October 2003 at 7:20 PM
I also have a UI dot tha makes the Main Window as large as posible without actually hiding the UI dots.
Zarabanda ( ) posted Thu, 16 October 2003 at 9:03 PM
les, thats a cool trick for maxing out the display with a ui dot
Silke ( ) posted Fri, 17 October 2003 at 7:47 PM
"Just grab them with the mouse and move them." DUH! Ok I am off to customize in a BIG way now. I can't believe I've been using poser all this time and I never knew that!!!
Silke
Silke ( ) posted Fri, 17 October 2003 at 7:56 PM
Oh here is another one, is there a way to sink the Poser 5 Parameter Dials window into the UI ala Poser 4? I much preferred that. :(
Silke
Kelderek ( ) posted Sat, 18 October 2003 at 4:07 AM
I don't think so... Sorry :-(
Cascade ( ) posted Sun, 19 October 2003 at 2:30 PM
Poser 5. 19" monitor at 1152 x 864 resolution. The document window is 700 x 525, I find it handy to keep a 4:3 ratio.
