-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
What size monitor and resolution are you all using? I have a 17" monitor and find that I have to set the resolution to 1024 by 768 to get everything in comforatbly but it does make all the tools quite small an my eyesight isn't what it was LOL!
Oh, let the sun beat down upon my face. I am a traveler of both time and space ....Kashmir, Led Zeppelin
You have to make sure you check "launch to preferred state" and "use Previous State". Also click a memory dot into the UI dots.
-Anton, creator of
since 3-13-07
I had a thread a day or two ago about the same thing in P5...but if you move anything above the tabs, they get locked up there...can't move them, can't use them... Was trying to vertical the toolbars, but forgot how...thanks for that reminder :)
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
I like your set yp Eowyn
-Anton, creator of
since 3-13-07
tabs are hard coded. You are stuck with em I believe
-Anton, creator of
since 3-13-07
not that I know of
-Anton, creator of
since 3-13-07
Actually, the tabs are specified in xml. To remove them, see here:
http://www.thenetherworks.com/Tutorial/P5-NoParadise.pdf
BTW, this was discussed over at poserpros.
Software: Daz Studio 4.15, Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM, RTX 3090 .
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
oops, corrections up there: The doc window is on the left, the tools are one the right. I need coffee :P LOL, I like Mason's
I'm left-handed (I'm betting there's a higher percentage than usual of us here), but I grew up in a right-handed world and/so the mouse is in my right hand, so it makes more sense to me to keep all the tools on the right. ~shrug~
Silke, you mean just to move the different things around? Just grab them with the mouse and move them. As easy as that. Then you can make sure that Poser loads it this way next time by going into "General Preferences" and set this as "preferred state". Also make sure that Poser loads to "preferred state" in the preferences, otherwise it changes back to the factory state next time. To change orientation of the rows with tool buttons, do ALT-left click on the title.
