Attached Link: http://snu2.tripod.com/lsrdesigns/
Hi Wabe, Many thanks for reply and have attached a sample as requested. SteveI think that good fir can only be achived in postwork...here is a great tutorial for brushing fur... http://www.lynescreations.com/quickfur.htm Lots of good hair and fur painting and brushing techniques posted here...plus some links to good brushes :) http://www.fignations.com/jelisa/tutorials/fur_and_hair.html
Well, if you read the intros to the images, the hair is always painted afterwards in Photoshop (or something like this). The same with Poser 4 images. Dynamic hair is not supported yet in Vue 4, so the only way is to paint it. I know Shari very well - her hair is painted :-))
I think a lot depends on the map itself as well. Lyne posted a lovely image in her gallery recently called The White Buffalo of Peace and the buffalo looks terrific!
Irene
Thank you for my white buffalo comment.. and yes it IS half "post work" because the older bison model maps so that the "banding" or stretching of the map- causing "lines" across one side of the animal just happens. Over the years mapping programs have improved, allowing the lay out of the map template to allow for either NO stretching or very little stretching! Each model/map is different... but in general the older models have this problem. In some of my own older models I have "blended" the ares that would have stretched or caused those lines... then of course they still need 'post' work with brushing or a clone tool. I did try to improve on an old model (the poser lion) when I did my morph and map set for it - doing a new map layout (that is incoded so as to be legal). Many artist are doing things like this to help.. AS for old models and old maps, then post "brushing" of the fur or feathers can help a lot. In photoshop (and I assume other paint programs) there are brushes that look like "splotches" or groups of dots.. these work very well as brushing out brushes...Used very sparingly.. I have a tutorial on brushing out fur - here is the Quick Short version of that: http://www.lynescreations.com/quickfur.htm Lyne
Life Requires Assembly and we all know how THAT goes!
Hi All, Can anyone suggest a way of reducing the lines, fake fur look etc when doing a final render in VUE. This can look especially bad when rendering close ups of the Daz wolf and bear textures. Any help would be appreciated. Many thanks, Steve.
