Sat, Jan 25, 7:30 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 6:57 pm)
Subject: Vuepro scene imported to poser
seeklight ( ) posted Mon, 20 October 2003 at 8:16 AM · edited Sat, 25 January 2025 at 7:28 PM
Lo all lo guys well today i am messing wiht the settings in vue pro for export scene. now the first pic is renderd in vue pro and the second and third are renderd in poser 4 this may be usefull if i can get the settings right ,then ppl can have entire vue scenes for there poser folk to wander about in lol,i am still trying to work out how to make shadows show up in the imported scene, any way just thopught id share this with you all second and third pic are in poser and one is set to center and the one were the tree and man are far away,all i did was move the poser camera way way back and thats it now all i have to figure out is setting the shadows in poser regards seeklight
seeklight ( ) posted Mon, 20 October 2003 at 8:17 AM
2
3
RawArt ( ) posted Mon, 20 October 2003 at 8:20 AM
I am wondering if Godot will show up LOL (sorry about the early morning exostentialism) Rawnrr
seeklight ( ) posted Mon, 20 October 2003 at 8:21 AM
Godot..???????
RawArt ( ) posted Mon, 20 October 2003 at 8:24 AM
Looks like a scene from a play by Samuel Beckett called "Waiting for Godot". ;)
seeklight ( ) posted Mon, 20 October 2003 at 8:29 AM
o i c lol haha ok soz seeklight
ChuckEvans ( ) posted Mon, 20 October 2003 at 9:56 AM
Would that mean the texturing would still need to be done manually in P4? (the tree looks a bit metallic...hehe).
seeklight ( ) posted Mon, 20 October 2003 at 9:59 AM
well the texture is the same as vue uses but as you know poser shine son everything and makes em look shiney and metal or plastic like. i never changed any settings in poser as i just wanted to see if it worked and it did ol regards seeklight
NVITWS ( ) posted Mon, 20 October 2003 at 1:01 PM
If what you're saying is that you imported a render from Vue to use as a background in Poser, fine, but you appear to be claiming to have exported a Vue scene (including that tree) to Poser. That's not possible. If you've figured out how to do it, by all means, let us know how it's done. It will be major news to a lot of people. Perhaps I've misunderstood something you wrote? Why would you want to export from Vue to Poser, rather than the other way around?
zandar ( ) posted Mon, 20 October 2003 at 1:07 PM
Looks to me like he imported the actual mesh, and not just a background image.
seeklight ( ) posted Mon, 20 October 2003 at 1:10 PM
well i have exported the whole scene ie tree ground and the atmosphere as well and yes it can be done if you have vuepro,i would not claim such a thing if it were not true seeklight
graphicnovel ( ) posted Mon, 20 October 2003 at 3:37 PM
vue professional can export whole scenes including tree meshes to different formats, just check e-on site for more info....
STORM3 ( ) posted Mon, 20 October 2003 at 5:47 PM
Does the sky come in as a background pic or is it mapped to a Vue object? I am very interested in how you did this. It might convince me to get Vue. Thanks
NVITWS ( ) posted Mon, 20 October 2003 at 6:20 PM
Vue is very much worth having for lots of reasons, not the least of which is that you can import Poser scenes into Vue, which for most purposes makes a lot more sense than doing things the other way around. graphicnovel, I appreciate your response and of course you're right that I should check e-on. I just found it odd that seeklight claimed to have imported everything including the atmosphere into Poser. So far as I'm aware, Poser isn't equipped to import Vue atmospheres, at least not P4/PP, which I use.
ChuckEvans ( ) posted Mon, 20 October 2003 at 8:46 PM
One possible reason for importing Vue scenery to Poser is for annimation. No need for the Mover software for Vue, then (right?).
graphicnovel ( ) posted Tue, 21 October 2003 at 3:36 AM
I don't know how the sky and atmosphere are imported but I know it works with max, maya and all objects together with terrains and trees can be exported.....sooooooooooooooooooo...... still there's a diference between vue and vue professional wich costs around 500 bucks... once again check the e-on site to find out more.... hope it helps vince
seeklight ( ) posted Tue, 21 October 2003 at 5:49 AM
Hey guys ok here it is.. the scene exports as a 3ds file format ie in this case ground tree and the atmosphere gets exported as a atmosphere box well its called a sky box to be exact. it exports the bmp map also now when you import it to poser you have to resize it all as the tree is very very small compared to the skybox,and to get the tree to the size it looks real compared to the size of your figure,you have to scale the whole scene up and over like 8 to 9000 in size. some trees and plants will not import as they are just to big in file size. i will try adding some mountains to the next one and il post screen captures for you all to see regards seeklight
yggdrasil ( ) posted Tue, 21 October 2003 at 7:12 AM
I haven't had much chance to play with VuePro myself, but from flicking through the manual at the weekend I recall seeing a section on exporting skies which allowed you to choose the type of mapping (cube, octohedron, sphere and dodecahedron I think) and resolution. -- Mark
Mark
