Sun, Nov 24, 8:34 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Posable props won't
Gromit ( ) posted Fri, 04 August 2000 at 2:16 PM ยท edited Sun, 24 November 2024 at 7:44 AM
All of a sudden a posable prop I downloaded and had tried before doesn't work. I get a message saying that Poser is unable to open the OBJ file. When I click OK on the error message box, Poser deletes the last figure in the scene, and the clothes that were parented/conformed to that figure are now moved to the origin. Then I get a message saying Poser is out of memory. Shutting down and re-starting doesn't help. I have 256Mb of RAM, maybe 3Gb of HD space available. Now NO posable props will load. I tried re-installing the props from the .ZIP files, no luck, same problem. Any ideas what causes this or what to do?
Oliver S ( ) posted Fri, 04 August 2000 at 4:01 PM
Have you put the .obj file where the prop file is looking for it? Open the prop file in a text editor and see where it is looking for the .obj file. You can edit the location if needs be...
mischief ( ) posted Fri, 04 August 2000 at 6:56 PM
i have several of differt messages from files i got but i got like 3 of the 10 props to work.
bloodsong ( ) posted Fri, 04 August 2000 at 7:30 PM
heyas; also try deleting the rsr that is with the obj in the geometries directory. if it becomes corrupted, poser will throw this error.
Gromit ( ) posted Fri, 04 August 2000 at 11:52 PM
These props worked before when I first downloaded them. I played around with them a little at that time just to see how they worked. I checked the CR2 file to see if the path to the OBJ was correct, the only difference was that the folder name was capitalized. I changed the OBJ folder name to match the CR2. I had tried re-installing the files from the original ZIP, but I changed that folder name AFTER I did that, so does that mean maybe the RSR file is still the problem? I'll have to try re-installing the RSR again after I get home this evening (morning your time). Gromit
Gromit ( ) posted Sat, 05 August 2000 at 9:38 AM
bloodsong, You got it! I renamed the .RSR file, tried it again. It worked, and the program re-created the RSR file when it couldn't find it. I suppose everyone but me knew it would do that, but I'm learning! Gromit
bloodsong ( ) posted Sat, 05 August 2000 at 10:57 AM
heyas; yup, that's how it works, gromit. so you can delete the rsr instead of renaming it; it won't stay gone forever ;)
bourne ( ) posted Wed, 09 August 2000 at 10:13 PM
I stumbled across that renaming trick too. I figured if Poser creates a .rsr file for cr2's then it probably create one for the .obj's. Ended up deleting a lot of corrupted props before I figured that out.
