Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 17 7:30 pm)
These props worked before when I first downloaded them. I played around with them a little at that time just to see how they worked. I checked the CR2 file to see if the path to the OBJ was correct, the only difference was that the folder name was capitalized. I changed the OBJ folder name to match the CR2. I had tried re-installing the files from the original ZIP, but I changed that folder name AFTER I did that, so does that mean maybe the RSR file is still the problem? I'll have to try re-installing the RSR again after I get home this evening (morning your time). Gromit
All of a sudden a posable prop I downloaded and had tried before doesn't work. I get a message saying that Poser is unable to open the OBJ file. When I click OK on the error message box, Poser deletes the last figure in the scene, and the clothes that were parented/conformed to that figure are now moved to the origin. Then I get a message saying Poser is out of memory. Shutting down and re-starting doesn't help. I have 256Mb of RAM, maybe 3Gb of HD space available. Now NO posable props will load. I tried re-installing the props from the .ZIP files, no luck, same problem. Any ideas what causes this or what to do?
