Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 16 7:48 pm)
Where did you put the folder = !DAZ ? The files being requested are in that folder. It needs to be in Runtimelibraries of the main P5 The !DAZVictoria3 BodyDeltas and HeadDeltas need to be the way they are installed. If you choose the move these files you must edit the paths in all of the pose files in the pose library to match your new location and that is just not worth the effort.
Write down the names of the problem files as Poser presents them. Open the pose file in a text editor. Look at the readScript line/path for the problem file. Trace the path yourself. You should then see what the problem is The content of the file that injects the deltas is not the problem. This is a location problem. You may only need to do one file to see a general problem. You may need to re-install if some INJ files have been deleted. You can install to a remote - empty folder - and pull over just the files you need If you have the upgrade - just put a copy of the V1 geometry file in the empty folder - with its entire path. Now - if this is a character pose from a 3rd party, the problem may be the character using the V3Male morphs and you not having them.
Thank you for the advanced info looks like I need to get my hands dirty in file goo then I guess. Is this a common issue ? I have all of the V3 and V3M inj sets its all DAZ3d for V3 I have. I just got around to installing and playing with her. I went to pop in the INJ all head set when I discovered the issue.Next I tried one set for the head at a time with no luck. only head inj's seem affected. Thanks again Jaager!
Howdy, I was just trying to use V3 with all SR's installed. When I try to load the head morph inj's I keep getting prompted to locate some ear and eye *.pz2 files why is this? What do i need to do to fix it ? It really messes P5/sr3 up. Thanks in advance.
