Fri, Sep 20, 7:27 AM CDT
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Carrara Free Stuff here.
Subject: 10 Minute Challenge
Kixum ( ) posted Thu, 06 November 2003 at 7:48 PM · edited Fri, 06 September 2024 at 10:31 PM
Based on the very cool image of the Christmas ornaments posted just a few threads down, I thought it would be cool to post a 10 minute challenge to make an image using a Christmas ball! Here's mine. -Kix
-Kix
Parkie ( ) posted Fri, 07 November 2003 at 1:34 AM
Well it took a little longer than 10 minutes as I am a little new to carrara.
Cheers
Neil
res1yfb1 ( ) posted Fri, 07 November 2003 at 1:50 AM
well this looked fun to do so i did this real fast. Kirk Saavedra
TOXE ( ) posted Fri, 07 November 2003 at 4:50 AM
in this period i have much fun with NPR (you had understood?;-) TOXE
falconperigot ( ) posted Fri, 07 November 2003 at 7:09 AM
On reflection, a fun challenge!
TOXE ( ) posted Fri, 07 November 2003 at 7:32 AM
hehe, looks good:-)
Kixum ( ) posted Fri, 07 November 2003 at 12:56 PM
These are all looking great! -Kix
-Kix
sfdex ( ) posted Fri, 07 November 2003 at 3:58 PM
OK, here's mine! I miss these ten minute challenges. (The environment took considerably longer than 10 minutes, but I'd built it a long time ago. Just thought there should be some story in the image -- at work, decorating the cubicle....) Ho ho ho!
FWTempest ( ) posted Sat, 08 November 2003 at 10:54 AM
my contribution... actually, I probably spent about 45 minutes on this one, primarily working on the Christmas lights... still learning what C3 can do. I spent so long exporting models out of C1.1 into Bryce to render, that the new C3 rendering engine is a simply amazing to me... still much to learn
azul3d ( ) posted Sat, 08 November 2003 at 11:28 AM
This one replaces my original entry which had some, should I say, physical inaccuracies. I just rotated the ornaments so that they are actually lying on the floor. This one took around 25 minutes to model and render. Rendered with one light, soft shadows, an image as a reflection map and a texture map for the floor.
azul3d ( ) posted Sat, 08 November 2003 at 11:30 AM
This is the same scene as above, but using global illumination.
sailor_ed ( ) posted Mon, 10 November 2003 at 6:13 PM
Well, I didn't make the 10 minutes either. After I figured out how to do it the image took about 45 including the render.
So what else is there to do when Renderosity is down? LOL
bluetone ( ) posted Mon, 10 November 2003 at 8:55 PM
How did you do that!? Is there a texture in the tranparency channel that gives the 'broken shard' look? Can you give a snapshot of your shader?
sailor_ed ( ) posted Mon, 10 November 2003 at 10:19 PM
Bluetone, You got it. I made two Xmas ornaments each with the same trans map (A jagged edge black on one side). Then I just inverted (black to white)the trans map on one of the ornaments to change it into the second piece. Actually each Xmas ball itself consists of two balls nested together. This is how you get the inside and outside shaders different. Hope that explains it. If not I'll work up a screen shot.
bluetone ( ) posted Tue, 11 November 2003 at 8:03 AM
Very cool! I was wondering about the inside shader. The other thought I had besides 2 balls was if you could, in the VM, set the inside of an object to different shader domains then the outside. Thanx!
sailor_ed ( ) posted Tue, 11 November 2003 at 8:29 AM
Bluetone, I couldn't figure how to do that. You would need to have control over both sides of a polygon.
Kixum ( ) posted Sat, 15 November 2003 at 4:37 PM
Excellent solution! -Kix
-Kix
