Wed, Dec 25, 8:14 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: smoother curves?
todd71_63116 ( ) posted Fri, 28 November 2003 at 1:39 PM · edited Wed, 25 December 2024 at 9:31 AM
i created an arch in illustrator then imported the paths into the spline modeler. i rendered with the hybrid, but the curves arent really smooth theyve got more of a flat line to them. what can i do to make them more rounded?
Kixum ( ) posted Fri, 28 November 2003 at 6:44 PM
Can you post an image of what you've got in the spline modeler? You can choose the smooth point tool and pull out a point on a line to smooth it out. -Kix
-Kix
Parkie ( ) posted Sat, 29 November 2003 at 1:27 AM
I found that I had to change the Surface Fidelity on the Geometry menu to get smother curves. I use around 200%. this does increase the polygons for the model. Cheers Neil
todd71 ( ) posted Sun, 30 November 2003 at 4:26 PM
like this one..id already rendered and finished the project..lol..the arch has a point at the top and one to each side to make the curver and then one at the bottom...i duplicated it then reduced the new one in size..so the inner line is the same as the outer..it just didnt render as smoothly as i thought it would...ill try the upping the surface fidelity next time to see how that helps..:)
todd71 ( ) posted Sun, 30 November 2003 at 4:28 PM
this was another example..its just a simple cylinder i kinda smushed into a 'coin'then made a shader for the side of it with the logo..even the outside of it didnt seem to render completely round...
mateo_sancarlos ( ) posted Sun, 30 November 2003 at 10:16 PM
I've noticed Illustrator paths get "unsmoothed" on import; the same path created with beziers in Carrara is smooth (pipeline, centered), but the Illustrator path needs to be redone to smooth it. Otherwise I suppose you could convert to vertex object and use subdivision smoothing level 2 if you want to keep the polygon count low.
todd71 ( ) posted Sun, 30 November 2003 at 10:21 PM
hmmm..ok..thanks for the advice...maybe we need a plug in that will import illustrator curves smoothly....=)..lol
