Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
M2HeadTr.jpg is the Michael 2 lash transparency, in DAZCharactersMilMan in the Poser Textures folder: you load that as the transparency map, bottom right of the materials dialogure in Poser 4. However, if you look in the Pose library you should find a folder of MAT files which will do the colorisation and texture application for you - I can't remember the folder name, since I combine them to avoid running out of slots (Poser 4 is limited to 255 folders per library).
Hi All.
I am starting of from the beginning. Poser 4, Mike 2, and Mike 2 medium resolution texture from Daz. Can someone point me to a tutorial on how to do eyelashes?
I started out by setting all the body parts in the Material box to white and applied the textures. Now I am down to the white eyelashes. How do I apply them?
Also, in the Materials box the first option is Preview. What is that?
Thanks for the help, DrOsborn
