Sun, Jan 26, 4:31 AM CST
Subject: Removing background image in P5?
TheWingedOne ( ) posted Mon, 08 December 2003 at 9:02 AM ยท edited Fri, 24 January 2025 at 10:58 PM
Hi all, I got a question regarding an issue I've stumbled in during a Poser job I did this weekend... I imported a background image for reference purposes. When I finished with the posing and ligthning I wanted to remove the image to change the size/resolution of the window as well as the rendered image. But I couldn't find a way to do so except storing the final figure and lights in a library and opening a new document. :( Not where user friendly though. Is there a better solution to improve this workflow? Thanks, Phil
randym77 ( ) posted Mon, 08 December 2003 at 9:10 AM
Yes, you can remove a background image. I don't have Poser on this machine, but I think it's under Display. You can hide or remove the background image, change the color, etc. To change the size of the window, I think it's under Window.
sirkrite ( ) posted Mon, 08 December 2003 at 9:20 AM
Clink (Display)-(Clear Background Image) it's about 2/3 the way down. The other is (Windows)-(Document Window Size) It's on the bottom.
Jackson ( ) posted Mon, 08 December 2003 at 9:23 AM
Right, select "Clear Background Picture" under the Display menu.
Dang cross post ;)
sirkrite ( ) posted Mon, 08 December 2003 at 9:37 AM
Hmmm. It is Picture not Image. ;)
TheWingedOne ( ) posted Mon, 08 December 2003 at 10:23 AM
Cool! Looks like I was kind of blind last weekend...blushing Better should have taken longer breaks from staring at the screen, but the job had to be finished because of a dealine. LOL. Many thanks for your help! Phil
SpottedKitty ( ) posted Mon, 08 December 2003 at 3:02 PM
And the same menu option is in Poser 4 as well, which helps me with a scene I'd messed up a bit -- I checked through my collection of sky backgrounds, selected the one that looked just right, and discovered I'd used the one that wasn't the same proportions as my work screen.
[thwaps self with wet haddock]
Gotta get a round tuit so I can read the rest of the manual. Ah well, now I can twirl the scene round the way I wanted it without having to "letterbox" the final render.
BTW, does it actually remove the b/g pic from the scene file, or just make it invisible?
sirkrite ( ) posted Mon, 08 December 2003 at 3:41 PM
The (Show Background Picture) shows and hides it. The (Clear Background Picture) deletes it.
sirkrite ( ) posted Mon, 08 December 2003 at 3:50 PM
Remember that the downside of using the background picture is it will always have it's resolution matched to whatever your work window is set to. So if you do a final render to another window at a larger size, your background will still be the resolution it was for the work window. For doing high-resolution backgrounds, uses the one sided square and apply your background picture to that as a texture. Or use something like Nerd's background tool.
TheWingedOne ( ) posted Tue, 09 December 2003 at 2:58 AM
Again many thanks for these lots of replies! :) @Sirkrite: For high resolution renders there's also the possibilty to do the render with a white (or black) background and save the result as an PSD file (Photoshop). Afterward you can import the figure/scene into any background, since Poser saves the PSD-file with a alpha channel included. :) Phil
