Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
JKELLER has a NO-GEN P4 Male CR2 and PCF over at the props guild that may solve your problem (or not). He removed the switch that changes out the hip geometries and fused the no-gen hip into the figure. There are actually two separate hips in the geometries folder so if both were not remapped you would have a problem. -JH.
You could try exporting the problem no-gen hip from Poser, then remapping it in UVMapper. Pull the male .obj into Compose. Delete the old no gen hip and replace it with the re-mapped version. I haven't tried this sort of thing with the male, so I don't know if there might be problems with this process due to the genitals switch.
No need to export, the no-gen hip part is right there in the geometries folder. The gen-switch consists of two parts under the second hip header: "alternateGeom hip_1", this is the switch, and "geomChan hipGeom" in the hip channels section. I've successfully added this feature to the EveGen figure, and can switch from a Gen to No-gen versions as needed. -JH. http://www.egroups.com/group/PoserTECH
I was wondering if that was possible! Will you be posting this version of Eve? Cool!
