Thu, Feb 13, 11:33 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Subject: Hair thingy-what export options are there?
maclean ( ) posted Wed, 23 August 2000 at 4:21 PM ยท edited Thu, 13 February 2025 at 11:27 AM
Can someone intelligent please clarify this for me. What format do I use to export and re-import the treemaker hair in a usable form? OBJ? 3DS? And how? Bear in mind that I haven't done much of this stuff yet. I'd appreciate it, as I'm trying to make a cat-woman with good hair (fur, whatever) Thanks maclean
Ihawk ( ) posted Wed, 23 August 2000 at 6:18 PM
I use .obj for mine, but keep in mind it won't look like it does in Poser - it will be triangles instead of strands. Poser just makes it look that way because it only displays the edge of each triangle, or something like that. Anyway, it will probably turn out appearing pointed instead of shaggy.
Kalypso ( ) posted Thu, 24 August 2000 at 12:29 AM
Site Admin
So far the most foolproof method was to export as 3DS, convert it to .obj (I use 3D exploration for that - you can find it here: http://www.xdsoft.com/explorer/ ) Now, I have also heard that if you open the .obj file in a text editor and change all the l lines to f lines you will retain the hairiness ??? Not sure of this as I haven't tried it myself. That's about as intelligent as I'll get before coffee :)
gsalas ( ) posted Thu, 24 August 2000 at 10:08 AM
What is the treemaker hair and where can you get it? -Gabe-
maclean ( ) posted Thu, 24 August 2000 at 12:28 PM
open poser and type in hair on the keyboard. Dialog box appears. Play with it. maclean
maclean ( ) posted Thu, 24 August 2000 at 12:32 PM
Thanks guys, Will play around with it and see what I get. Gabe, Look in the messages over the last 10 days for more info. There's been a lot of discussion on it. Under 'hair thingy' usually maclean
