I had the same problem but the IPB was not pointing to M3 and I didn't see that for a while. I uninstalled (delete) and reinstalled everything with the updates then it worked correctly.
From what you describe, it sounds as if you are not selecting 'Michael 3' in the 'Figure' dialog (F2) prior to processing the face file. The default option is 'Victoria 3', as such IPB is using an internal dictionary containing file paths that are specific to the selected figure, Victoria 3. The resultant pose is likely injecting delta information as it should, the problem, however, is that it is information specific to Victoria 3. -Rob
