Tue, Jan 21, 10:13 AM CST
Subject: Need help with a background.
Ardiva ( ) posted Wed, 24 December 2003 at 2:46 PM · edited Tue, 21 January 2025 at 10:10 AM
I would like to create a Sc-Fi scene in Bryce, but I also would like to create the starry background with Universe. So my question is..is there a way of importing this background (which will be in .BMP format) into Bryce and using it instead of one of the regular Bryce backgrounds? Thanks in advance..
drawbridgep ( ) posted Wed, 24 December 2003 at 2:54 PM
I put it on a massive 2d plane in the background. Never sure if it's the right way to do it, but works OK. But needs a bit of fiddling with the lighting. I'd be interested to see if there's a better way of doing it.
Phillip Drawbridge
Website
Facebook
RodsArt ( ) posted Wed, 24 December 2003 at 3:22 PM
Lots of different ways, You could leave it blank, when you finish with your main scene, Mask render all objects. Render a star scene and save that, then layer them together in Photoshop. Do as drawbridgep says with a 2D plane & star material, or also on a sphere. Masking out layers will allow you much more control, You can also touch up the background with Universe Image creator which makes some great space fields. Good Luck & let us know how you make out. Happy Holidays ICM
___
Ockham's razor- It's that simple
RodsArt ( ) posted Wed, 24 December 2003 at 3:28 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=438739&Start=19&Artist=ICM&ByArtist=Yes
This Image has the nebula on a sphere & I used Universe Image Creator for the stars. I masked the stars & pasted them in, erasing the masked stars to fit the scene. I also made the sphere semi transparent & put a strong radial light on the outside of the shpere. Have Fun!
___
drawbridgep ( ) posted Wed, 24 December 2003 at 3:31 PM
That looks great!!! I'm gonna try that.
Phillip Drawbridge
Website
Facebook
Ardiva ( ) posted Wed, 24 December 2003 at 3:43 PM
Thanks all. .ICM..that is exactly what I will use (Universe Image creator)..I was just seeing if I could import the completed universe file into Bryce as a background. Thats all. :-) Cheers!
RodsArt ( ) posted Wed, 24 December 2003 at 3:59 PM
Attached Link: http://hubble.nasa.gov/
Search through this site for some Amazing Hubble images. Great for 2d's & Spheres.
___
pakled ( ) posted Wed, 24 December 2003 at 6:50 PM
one technique used is to create a sphere, and texture it with a star mat, I think I've seen a few (galaxy and galaxy1, I think at Wolfie's Den..I think). Put your scene inside the Sphere, bring in a light to suit (I use radials because they render faster..well, never mind..;), and whatever you want to render. A quick tip- sometimes it helps to delete the basic plane, or you get 'horizons' in space..;) You might also turn off the shadows in lighting, because nothing says 'wrong' like a shadow on a planet..;)
Ardiva ( ) posted Wed, 24 December 2003 at 7:08 PM
Thank you all for your very kind help. I sure appreciate it!
