Sun, Feb 2, 11:50 PM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2025 Jan 21 7:59 pm)
Subject: thumbs
Fobialic ( ) posted Thu, 01 January 2004 at 9:18 PM · edited Thu, 30 January 2025 at 10:13 AM
strangely anny thumb i send in seems way out of balance of my original pic i do this in psp7 after i save in jpeg and then create a thumb of it and send it in its way off can anybody help me here pls? tnx in advance
Rykk ( ) posted Thu, 01 January 2004 at 10:52 PM
Hi! Have you checked the amount of compression being applied to the jpeg thumbs? If its set at a really high percentage it might be the cause of your colors being off or blurring. I, typically, set the compression with PSP on the big copy of my images at the lowest possible - 1% - and then look for the lowest possible compression that gets my thumbnails in under Renderosity's 15kb limit - usually around 10-15% or maybe around, say 25% if there are a lot of flames or if I apply the "sharpen" filter to the thumb. I usually start with a 1024x768 (my screen res) bmp generated by Ultrafractal and re-size it as an 800x600 jpeg with 1% compression, then re-size that to 200x150 and save as another jpeg with the minimum compression I can get away with. Hope this helps. Rick
paragon5 ( ) posted Fri, 02 January 2004 at 1:00 AM
I have a program called "A Smaller Image" that does my thumbnails. I use just enough compression to get under Renderosity's limit ( just as Rick said). William
shood ( ) posted Fri, 02 January 2004 at 7:02 AM
Do you mean out-of-balance colorwise or size? The free program called Irfanview can take any size/type image and create a thumb to any size or compression, besides being able to add sharpening.
