Sun, Jan 26, 6:35 PM CST
Subject: Template size
d4500 ( ) posted Sat, 03 January 2004 at 8:39 PM ยท edited Sat, 25 January 2025 at 6:02 PM
I understand you can make templates any size you wish (such as 1500x1500). But I was wondering how does Poser know where to look for the images it needs... such as eyes, face, etc?
SamTherapy ( ) posted Sat, 03 January 2004 at 8:48 PM
You have to tell it where to look. Either by applying the textures manually from the Materials editor/Room, or by a MAT pose.
d4500 ( ) posted Sat, 03 January 2004 at 9:01 PM
Thanks. I was more concerned with how a single image lines up prefectly on the model (such as a face) no matter how large the painted texture is. For example, if you have a small picture, it will fit on the screen... but if it's too large, you can only see a part of it on the screen (oversize). However, you can load a 150x150 or a 1500x1500 texture and it fits perfectly on the model? I guess poser automatically adjusts texture alignment according to the size of the map.
Spanki ( ) posted Sat, 03 January 2004 at 10:04 PM
It works like this... UV coordinates are not pixel placements, they are values that represent a 'percentage' across or down the image in question. So a value of 0.0 is the left/top-most pixel position, a value of 0.5 is halfway across/down the image and a value of 1.0 is the right/bottom-most pixel position of an image - regardless of the image's dimensions. (Note: some apps use a bottom/left position of 0/0, some apps use a top/left position as 0/0.. I'd have to double-check to see which one Poser uses, but I think it's top/left). Does that help?
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
d4500 ( ) posted Sat, 03 January 2004 at 10:52 PM
Yes... but I could really use some help with my newest post topic (above)... texture model.
Dizzie ( ) posted Sun, 04 January 2004 at 5:38 PM
Thanks Spanki...a great explanation...I was wondering that myself!
