Tue, Nov 26, 12:54 AM CST
Subject: Ideas anyone?
amethyss ( ) posted Wed, 07 January 2004 at 12:40 AM · edited Tue, 26 November 2024 at 12:48 AM
I am trying to make a certain object,but getting brain drain.Can anyone help steer me in the right directon?Or know of a link to find such a critter?
Painting: The art of protecting flat surfaces from the weather and exposing them to the critic_____website
Flak ( ) posted Wed, 07 January 2004 at 1:09 AM
is that like a cone with the top cut off?
Digital WasteLanD
Flak ( ) posted Wed, 07 January 2004 at 1:10 AM
err... booleaned off I mean.
Digital WasteLanD
amethyss ( ) posted Wed, 07 January 2004 at 1:34 AM
Well sort of... I need it to be a solid object. Like a base.Not sure what booleaned off is though.
tresamie ( ) posted Wed, 07 January 2004 at 2:00 AM
Like this? It's a truncated cone, sorry about the mat :(. Wireframe in next message.
Fractals will always amaze me!
tresamie ( ) posted Wed, 07 January 2004 at 2:01 AM
wireframe
tresamie ( ) posted Wed, 07 January 2004 at 2:03 AM
The cone is set to positive, the cube is set to intersect, the group is set to positive (all in A attributes) Both the cube and cone have the same mat. I hope this helps. Tres
amethyss ( ) posted Wed, 07 January 2004 at 2:23 AM
Awsome Thank you.Going to try this now.
bikermouse ( ) posted Wed, 07 January 2004 at 2:59 AM
amethyss, boolean it as above and make a distance render. use the distance render with a terrain. That'll get rid of the brain drain for sure. - TJ
TheBryster ( ) posted Wed, 07 January 2004 at 7:30 AM
Forum Moderator
Tres: Both objects don't have to have the same .mat. You could turn off transfer of material when booleaned on the negative object. (Although you probably knew that)
jedswindells ( ) posted Wed, 07 January 2004 at 7:34 AM
Alternative...a terrain. Terrain editor-New-Blobmaker,3 taps.-raise,a lot and it will flatten off.-smooth,several taps.-clipping brackets,lop off bottom. Well,mine looks like your sketch but it isn't a solid.
tresamie ( ) posted Wed, 07 January 2004 at 11:32 AM
Thanks Bryster, I didn't know that (I only have about 3 tricks, and now have used up one, lol) However, there was no negative object in my example, just one positive, one intersect and group positive. Does it still work?
TheBryster ( ) posted Wed, 07 January 2004 at 7:07 PM
Forum Moderator
Tres: Beats the hell outa me.......!
