Mon, Feb 3, 9:02 PM CST
Subject: Hat pin
Butch ( ) posted Fri, 09 January 2004 at 8:49 PM · edited Mon, 03 February 2025 at 9:00 PM
Anyone know where I can find an old fashion hat pin? Thanks
hauksdottir ( ) posted Fri, 09 January 2004 at 11:08 PM
Can you make one? A dance cane or cylinder prop can be scaled to the right proportions. Add a fancy top thingy if you wish or just use a sphere... parent it to the pin, export as a single object, and then reimport at your desired size. Some of the Japanese hair pieces at the Edogoyomi site have what look like hairsticks, which could be scaled down to hat pin size as well. Carolly
randym77 ( ) posted Fri, 09 January 2004 at 11:12 PM
Why don't you post a picture of what you want? If it's a simple hat pin like this one, it would be easy to make, and someone would probably make it for you.
Butch ( ) posted Fri, 09 January 2004 at 11:45 PM
that's exactly what I need.I have tried in the past to make props but unfortunely I don't seem to have the knack for it. It like the old shop joke, no matter what I make it ends up being an ash try, just cut two grooves in it and you got an ash try...
randym77 ( ) posted Fri, 09 January 2004 at 11:53 PM
LOL! I'm sure someone will make one for you. If not, I can probably do it, beginner though I am. I'll check this thread tomorrow, and if the resident experts haven't stepped in, I'll take a stab at it. ;-)
Scarab ( ) posted Sat, 10 January 2004 at 1:06 AM
Do a net search for a free ware called "spatch"....it has a very very low learning curve but can produce simple props in dxf format which you can import into Poser. Cant be textured but still a usefull tool. Scarab
lesbentley ( ) posted Sat, 10 January 2004 at 8:16 AM
Load a ball prop, use the grouping tool to assign a new material to it called 'Ball'. Load a cylinder, assign a new material to it called 'Pin'. Scale the cylinder to 43%, yScale it to 3000%, yTran it to 0.080. Use a magnet to pull the top cylinder cap into a point. Export a Wavefront OBJ containing both props. Reimport the obj, apply a silver reflection map to the pin material and set the Reflective and Highlight color to white, Object and Ambient to Black, set whatever colour you like to the ball, rescale the prop to 3 or 4%, then save it to a props pallet, call it "HatPin".
hecate ( ) posted Sat, 10 January 2004 at 9:50 AM
I've got these and also one with a tear-drop shaped head. I can make them available easily enough.
Scarab ( ) posted Sat, 10 January 2004 at 10:44 AM
Please do ....they are very nice... Scarab
Dizzie ( ) posted Sat, 10 January 2004 at 2:06 PM
DITTO...they're beautiful!
Dizzie ( ) posted Sat, 10 January 2004 at 2:33 PM
lesbentley, I tried your mini tut and I used the grouping tool to assign a new material to it called 'Ball'and did the same for the cyclinder but when I import it back in, there is no separate materials for the pin and ball...
hecate ( ) posted Sat, 10 January 2004 at 2:42 PM
I'll post these as a package to freestuff in a bit.
randym77 ( ) posted Sat, 10 January 2004 at 2:57 PM
Wow, those are lovely! I knew someone would come through for Butch. :-D
hecate ( ) posted Sat, 10 January 2004 at 3:14 PM
Attached Link: http://www.fishyworld.net/model.php
Hatpins submitted to freestuff. For those who are impatient, here's a direct link to the site. 8-) Hope they're enjoyed.
Dizzie ( ) posted Sat, 10 January 2004 at 5:19 PM
These are great! Thanks!
hauksdottir ( ) posted Sat, 10 January 2004 at 5:35 PM
Very pretty set of pins... thank you!
Scarab ( ) posted Sat, 10 January 2004 at 5:59 PM
Yay! 8) S.
