Fri, Nov 29, 7:03 PM CST
Subject: 1st Time Trans Hair - Problems
Luna ( ) posted Fri, 01 September 2000 at 4:03 AM ยท edited Tue, 26 November 2024 at 9:48 AM
Well, I Exported The Fantasy3 Hair Unchecking All Since It Has No Object. I Then Mapped It At 600x600x300dpi. Took It Into Painter6 And Attempted To Follow Kazaburo's Tutorial On Hair. Well, The First Time I Did It (Left) Looked Like I Was Going in The Right Direction. But After Trying The Second Time And Thinking I Really Had a Good One...You Can See It Looks Like Complete Crap. (Right Image) Not Sure What I Am Doing Wrong, But Thanks For Any Help You Might Offer.
Stormrage ( ) posted Fri, 01 September 2000 at 8:03 AM
hmmmm.. the first one looks good.. If you applied several of the same hairs to her head it might fill it out more. on the second I can't see the transmap really well did you apply trans Min and Max in the properties? Storm
Jim Burton ( ) posted Fri, 01 September 2000 at 8:04 AM
How big are your maps? For something this big you are goung to need a pretty big map, 3000 x 2000 pixels at least. The DPI is meaningless, as is the size of the template you make in UV Mapper - it is the actual maps that have to be big. Also bear in mind the limitations of trans mapping a single surface mesh - if an area is transparent, what is going to show underneath?
Luna ( ) posted Fri, 01 September 2000 at 8:43 AM
Thanks Storm! I'll Keep Trying. No I Didn't use Both Min And Max Thanks Jim! I've Tried a Couple. The One I Am Working With Now Is 600x600 As I Posted Earlier. With Much Help This Morning From Rkane I Got Some Good Tips. Suggestions On Layers (Might Help With What's Underneath)I Got A Slightly Better Effort. See New Post Please. Thanks You Two Again
