Carrara F.A.Q (Last Updated: 2025 Feb 10 2:42 pm)
When you use the "add cylinder" function, the above image is the only way to do it. I prefer, when mapping is involved, to create the cylinder in the spline modeling room. That way you can better control the surfaces that are being mapped onto with the parametric mapping funcion. (side 0, side 1, side 2, etc) Good luck! Mark
I figured out how to apply a decal on the topside of a spline made cylinder with the anodized aluminum shader as a master shader ,thanks to your tips.But I ran into one problem after all my fussing with getting iy on there right. It was reflective just like the metal sheader, so I made a new layer of aluminum and applied it to the bottom, the main shader to the sides and a texture map on top. Bingo.
