Wed, Feb 5, 1:13 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Oval layer on top of cylinder
kaom ( ) posted Fri, 01 September 2000 at 7:21 PM · edited Wed, 05 February 2025 at 12:58 PM
Can anyone tell me how to get a circle layer on top of a cylinder? It doesn't let me tweak the points correctly to resize it to cover just the top surface, can this be done?
MarkBremmer ( ) posted Fri, 01 September 2000 at 10:46 PM
ovalmap.jpg When you use the "add cylinder" function, the above image is the only way to do it. I prefer, when mapping is involved, to create the cylinder in the spline modeling room. That way you can better control the surfaces that are being mapped onto with the parametric mapping funcion. (side 0, side 1, side 2, etc) Good luck! Mark
kaom ( ) posted Fri, 01 September 2000 at 11:46 PM
Thanks for the response. I think this might solve the problem, How do I adjust the size of the oval layer to cover the entire top surface with numeric values. The points around the oval layer are a pain to control and be precise with?
kaom ( ) posted Fri, 01 September 2000 at 11:57 PM
What & where is "add cylinder"????,by the way?
kaom ( ) posted Sat, 02 September 2000 at 2:48 PM
I figured out how to apply a decal on the topside of a spline made cylinder with the anodized aluminum shader as a master shader ,thanks to your tips.But I ran into one problem after all my fussing with getting iy on there right. It was reflective just like the metal sheader, so I made a new layer of aluminum and applied it to the bottom, the main shader to the sides and a texture map on top. Bingo.
MarkBremmer ( ) posted Sat, 02 September 2000 at 9:55 PM
Half the fun is getting there!
