Sun, Feb 9, 8:20 PM CST
Subject: FireFly Reflection mapped and Mirror Ray trace reflection to Car.
DarkMatter_ ( ) posted Thu, 15 January 2004 at 11:33 PM ยท edited Sun, 09 February 2025 at 8:11 PM
this was tough and tedieus and took and took awhile to do, it also took an hour to render. The car has a reflection map, And a ray trace reflection. Rendered in poser 5 The sky reflections were done with a sky plane over the car so the car would pick up the sky reflections in raytracing render. The bottom reflection was done on the ground plane with a mirror reflection setting, I then later took the image into paint shop pro and gave the bottom reflection a ripple effect with a paintshop6 pro filter.
DarkMatter_ ( ) posted Thu, 15 January 2004 at 11:34 PM
car image, the cup was done the same way but tok less time being that it had fewer nodes.
DarkMatter_ ( ) posted Thu, 15 January 2004 at 11:47 PM
Ill tell you something else, I like poser4 for quick renders,minor texture editing and figure editing. Poser5 even with 2.5 gigs of memory on a pentium 4 is still lagging, It's now a program I can use but it's still not as fast as poser4. But since it has a really good rendering engine I use it to do my final renders now and for some of the perks it has. My other computer I am retiring since christmass, is Pentium 3 and poser5 made it run like molassis. .....
biggert ( ) posted Fri, 16 January 2004 at 12:40 AM
excellent friggin renders man!! OK....it looks like your pretty experience with reflection nodes....can you help me figure out how to eliminate these jagged edges in P5? i've tried the following----> 1. Quality in reflection node was set to 0 and 1 2. Raytrace bounces set to max 3. Pixel Samples set to max 4. softness value set from 0-1 i cant figure out how to eliminate these jaggies in the reflection.... got any ideas? thanks for any help. much appreciated!
DarkMatter_ ( ) posted Sat, 17 January 2004 at 3:03 AM
Try upping your screen resolution in control panels that should take care of it.
DarkMatter_ ( ) posted Sat, 17 January 2004 at 3:09 AM
1280 by 960 is what I use to get rid of jaggies.
Literata ( ) posted Sat, 17 January 2004 at 11:02 AM
Any chance you could show the node setups on the materials in the scene? When you mention that the car has a reflection map, and a ray trace reflection, I'm not certain where to put those nodes (does that make any sense?) Thanks
