Wed, Nov 13, 6:35 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: a carrara qeustion??
epsilon ( ) posted Sun, 03 September 2000 at 2:36 AM · edited Mon, 11 November 2024 at 2:19 AM
is it posible to fade in and out an object in carrara..insted of just using the no visable key but actually fade in and out an object in the scene.. eg..star trek -beemimg captain kirk to another planet..only example i could think of epsilon-graphix epsilon :)
willf ( ) posted Sun, 03 September 2000 at 10:11 AM
You could use transparency for the object and increase the "ammount' over time. Could also use a gradient in the shader to control transparency from top to bottom etc. Could even map a movie of a graduated gradient to the transparency channel to make a graduated fade effect.
epsilon ( ) posted Sun, 03 September 2000 at 10:41 AM
thanks:?) epsilon
willf ( ) posted Sun, 03 September 2000 at 10:46 AM
You could also use the dissolve modifier on the object & have look like it's dissintegrating.
litst ( ) posted Sun, 03 September 2000 at 2:49 PM
Hi epsilon, i think the best way to achieve that effect is to put a "multi channel mixer" in your shader . Put your shader in "source 1", a transparent material in "source 2", and a value in "blender" . Then, move that value slider to see the fading effect . This way, you only have to animate the slider .
