Mon, Dec 2, 12:06 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Carrara Free Stuff here.
Subject: Poser 5 Figure into CS3
kits ( ) posted Tue, 20 January 2004 at 4:07 PM · edited Fri, 29 November 2024 at 10:48 PM
Hi all got a problem when I export a poser 5 character as an obj file to CS3. When I open it up the eyeball textures are gone, making the eyes appear all white. The rest of the body and the head textures are fine. This does not happen when I do the same with a poser 4 figure. and the only workaround that I have found is to remap the P5 eyeballs with a flat map and use a normal square map. Has anyone figured out how to get the poser supplied UV map to work properly. Any help at all on this would be greatly appreciated. Chris_S
todd71 ( ) posted Tue, 20 January 2004 at 4:09 PM
are they gone in the preview or when you render? thought maybe it might just be a preview issue...
kits ( ) posted Tue, 20 January 2004 at 4:17 PM
They are gone in both the preview and the render. Chris_S
Patrick_210 ( ) posted Tue, 20 January 2004 at 5:21 PM
Probably the extra glass ball they put around the eyeball. Try isolating some of the eyeball parts and checking the invisible box to see if that's the problem.
kits ( ) posted Tue, 20 January 2004 at 5:38 PM
THanks Patrick will give what you say a try Chris_S
mateo_sancarlos ( ) posted Tue, 20 January 2004 at 7:00 PM
Search further down the list here. There is a nice tutorial on P5 to Carrara. If the boss would put it in the tutorial section, it would be easier to find.
Kixum ( ) posted Tue, 20 January 2004 at 7:25 PM
Ok, I can take a hint. -Kix
-Kix
kits ( ) posted Wed, 21 January 2004 at 4:29 PM
Thanks All Patrick had the right of it. once I made the eyeball cover and the iris cover transparent there was the texture in place all the time. I'm new to CS3 and I'm a slow learner. Once again thanks Chris_S
