Thu, Jan 9, 7:38 AM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
Subject: UF3 Kaleidoscope
Earlydawn ( ) posted Sat, 31 January 2004 at 10:47 AM · edited Fri, 27 December 2024 at 4:04 PM
When I use the kaleidoscope there is always a line down the center, is there a way to make that line go away? Thanks, Cherie
TheRingess ( ) posted Sat, 31 January 2004 at 11:29 AM
Actually yes. The kaleidoscope transform that comes in the standard file has a minor but. The one in the dmj file has corrected that bug. alternatively, in the location tab, if either one of the coordinates of the center is 0, change it to something really, really small, like 0.00000000001. This will get rid of the line without changing the look. Hope that helps
Earlydawn ( ) posted Sat, 31 January 2004 at 4:29 PM
Thank you sooooo much, that worked perfect...hugssssssssss
abmlober ( ) posted Mon, 02 February 2004 at 9:14 AM
There are several other effects with the center of an image at (0,0). I have written a geometric UCL that works with the pixel formula and creates unwanted lines. You can rotate by a tiny amount or shift by a tiny amount to get rid of this UF bug...
:rolleyes::sad:
Joy of Frax
Earlydawn ( ) posted Mon, 02 February 2004 at 9:23 AM
Thank you, I have noticed a few other lines I didn't really think should be there, I will try that, guess you get a hug too!
Aeneas ( ) posted Tue, 03 February 2004 at 12:25 PM
And a hug for Janet Preslar too I suppose...In the very first tutorial in the manual of UF3 (page 16) she mentions these black lines and how to get rid of them.
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
Earlydawn ( ) posted Tue, 03 February 2004 at 12:29 PM
My bad, hugs to everyone
