Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
I've also seen this some times if the object is double sided or if there are two planes too close together. If you've used two plans to simulate thickness either move them further apart or (and this saves memory) delete the inner vertices, you cna't see them when the object is on a poser figure anyway andleaving the edges still gives the illusion of thickness. mike
