Thu, Jan 23, 1:03 PM CST
Subject: Is it safe to delete Poser 2 Hi/Lo crap???
dlk30341 ( ) posted Thu, 05 February 2004 at 6:48 PM · edited Thu, 23 January 2025 at 12:58 PM
As stated above. I'm trying to clean up my folders & noticed quite a few Poser 2 stuffs . I have never even looked in these. Also, how about Figures labled Poser 4 hi/lo, figures as well. I'm these are the dork etc. I have no use for these. Just want to make sure before I hit delete Poser won't freak out. ;) TIA
Zarabanda ( ) posted Thu, 05 February 2004 at 6:56 PM
go ahead and delete them, those character files aren't referenced by anything.
dlk30341 ( ) posted Thu, 05 February 2004 at 7:03 PM
Thank You!!! Off to do more tidying ;)
geep ( ) posted Thu, 05 February 2004 at 7:09 PM
Hi dlk30341,
A friendly suggestion ... ;=]
Make a new folder named "OldPoserStuff" (or whatever) and "move" the characters, props, etc. to the new folder.
If you start Poser and you have accidentally deleted (moved) something Poser wants, you can easily find it and restore it.
After you are satisfied that Poser is still "happy" after you have made your "deletions," then you can delete everything in the "new folder."
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
dlk30341 ( ) posted Thu, 05 February 2004 at 7:37 PM
Thanks Dr. Geep..Poser is still happy LOL...I deleted tested, all A OK,,dumped the bin. I love dumping the bin :)LOL I figured the Poser stuffs came from the CD's from PoserWorld.....Cleaning house is a good thing for the HD.....;)....I have 3, One is used for textures CD's & clip art, that I've purchased over time, 1 is for backup, the other is Main. 160g is down to 54.2G :O, no thanks to Poser and Vue stuffs. Thanks folks for all your help, as usual:)
geep ( ) posted Thu, 05 February 2004 at 8:05 PM
cheers,
dr geep ... :o]
edited 10/5/2019
DarkMatter_ ( ) posted Thu, 05 February 2004 at 9:58 PM
First do you really want to do that, poser 2 figure make great store mannquins for store frount scene and crach dummies. If you want to get rid of them you can, poser wont care or miss them.
Little_Dragon ( ) posted Thu, 05 February 2004 at 10:03 PM
Walk Designer uses the Nude Man P4 Lo.cr2 and Blendloman.obj by default. Normally, if you remove those, Walk Designer won't work properly.
But you can change the default to something else.
DarkMatter_ ( ) posted Thu, 05 February 2004 at 10:42 PM
yeah thiers tons of crap in poser you can get rid of and get space back in return...
DarkStarRising ( ) posted Fri, 06 February 2004 at 8:00 AM
ha ha, DarkMatter, nice image! i been deleting a hell of a lot of old poser style gumph from Pro Pack, i even got rid of the Pro Pack bunch, lol! i seem to find, well with my poor machine anyhoo, deleting a lot of the old style poser stuff, i has been working that much better, only just mind, lol
In the words of DarkStarRising:
"Sadness within sadness,
Darkness within darkness,
a shadow of a form lays upon the floor,
looking at herself
looking at her own shadows of loneliness"
dlk30341 ( ) posted Fri, 06 February 2004 at 9:23 AM
LOL on the pic!!!! I don't do animations so walk designer is of no use to me. As far as mannequins..I think any of the V1-3 or M1-3 would make good mannequins....just leave them as is ;-).
cyberscape ( ) posted Fri, 06 February 2004 at 10:25 AM
You mentioned 160gb being whittled down to 54.2! WOW! One thing though, I've heard from several reliable sources that the true capacity of any IDE-type harddrive is roughly 55% of it's total rated size. If you use a "scuzzy"-type HD, you're okay. Otherwise, try to get back up over 80gb. You will see a marked improvement in the overall speed and performance of your computer. The reason is, IDE HDs read/write from the center and work closer to the outer edge as they get full. The inner circle has less surface area. Therefore, the data can be read faster. This is why defragmenting helps as IDEs tend to skip spaces when they write data, moving closer to the outer edge. Defragmenting pushes all the data back towards the middle, removing the blank spaces. I know... what does this have to do with Poser 2 crap? Nothing. Just wanted to give a good tip to those who don't know about this :) and... cool pic DarkMatter!!
AMD FX-9590 4.7ghz 8-core, 32gb of RAM, Win7 64bit, nVidia GeForce GTX 760
PoserPro2012, Photoshop CS4 and Magix Music Maker
...and when the day is dawning...I have to say goodbye...a last look back into...your broken eyes.
