Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Jan 05 8:10 pm)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
Teyon, and BazC, thank you very much for your responses.
As BazC, mentioned, C4D can control it. I just used the default value. I have lots to learn for modeling.One of the reason for high polygon count was the many curves of the sword. But certainly I could control it.
I also noticed that someone mentioned "Nurbs" in Cinema aren't really Nurbs in Cinema forum. Does real Nurbs have more capability. Someday, I should try Rhino.
I was thinking about fantasy sword, so the texture did not show realistic sword.My main concern was the texture of blade. I was straggling to get realistic sharp blade. Blade is very hard for me.
Thanks again.
Himico,
I am learning modeling. I would like to have your comments, and suggestions, please. The picture is a sword I made using Cinema4D. I mainly used sprine & Loft Nurbs, and Boolean. It seams easier to control the shape with sprine & Nurbs method. The modeling was made by my own way. I am not sure whether this is good way or not.
Polygon count is pretty high about 23k without the cross. Is the 23k too high ? The tiny cross made using Zbrush is 39k which is very high. I should delete this, and use texture map.
Any better alternative way to make sword?
How would you make blade ?
I saw nice low polygon blade modeling of Moebius87. But, my own problem is that I am beginner, and I cant understand how you made it by simply looking at wire frame picture..
Thank you for your helps in advance.
