Fri, Jan 3, 8:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 03 8:14 am)
Subject: poser animation more than 999 images
Ede ( ) posted Mon, 11 September 2000 at 8:20 AM ยท edited Thu, 25 July 2024 at 6:28 AM
hi, i've just renderes an animation created by mimic it rendered with about 1030 images, but poser did just display 999 is there a way to work with more images? -Ede
LoboUK ( ) posted Mon, 11 September 2000 at 8:44 AM
I've had animations of 2,000+ frames (built at 500 frames per time and added, one after the other) with no problem. Unfortunately, Poser can only display a count for the first 999 frames - that's all the space that the counter allows. But, the missing frames are still there, at the end of the animation - it's just that you need to use the arrow to get to them as the counter doesn't go that high. Paul
Ede ( ) posted Mon, 11 September 2000 at 8:46 AM
good to know, thats what i thought, but wasn't sure if it's a bug or a feature :-))) thanks paul -Ede
milamber42 ( ) posted Mon, 11 September 2000 at 11:43 AM
Something for the Poser 5 wishlist or for an update -- 4 digit counters.
Ede ( ) posted Mon, 11 September 2000 at 12:03 PM
5 digits for me :) i know myself g -Ede
Kevin ( ) posted Mon, 11 September 2000 at 3:22 PM
The answer I have seen from professional animators is that you should not use any scenes that long. To quote one "You're not Alfred Hitchcock, and Rope wasn't done in one take anyway." Use shorter scenes and edit them together in Premiere or another editor. They probably will make the counter longer, but it still doesn't mean it is a good idea.
nitreug ( ) posted Mon, 11 September 2000 at 9:46 PM
I think the counter stop at 999 but the animation go further. I am using it with new animation from credo and they goes really further than 999 but I can see everything even if the counter does not show more. Claude
