I've had animations of 2,000+ frames (built at 500 frames per time and added, one after the other) with no problem. Unfortunately, Poser can only display a count for the first 999 frames - that's all the space that the counter allows. But, the missing frames are still there, at the end of the animation - it's just that you need to use the arrow to get to them as the counter doesn't go that high. Paul
The answer I have seen from professional animators is that you should not use any scenes that long. To quote one "You're not Alfred Hitchcock, and Rope wasn't done in one take anyway." Use shorter scenes and edit them together in Premiere or another editor. They probably will make the counter longer, but it still doesn't mean it is a good idea.
hi, i've just renderes an animation created by mimic it rendered with about 1030 images, but poser did just display 999 is there a way to work with more images? -Ede
