Tue, Nov 19, 10:48 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: SVDL - De-skate script
numanoid ( ) posted Tue, 03 February 2004 at 7:27 PM · edited Tue, 19 November 2024 at 8:48 AM
Hi,
Got a small problem. I was using this script and was having great succes with it.
Now I am using this one, and I can't seem to figure out how to get the figure selected. Am I just being an idiot?
svdl ( ) posted Tue, 10 February 2004 at 4:54 PM
Ah. Simple problem, actually. The new version of the walking script assumes the walking figures have actors with internal names lFoot and rFoot. If no such body part can be found, the script assumes it's not a walking figure. Search for 'ActorByInternalName("lFoot")' and 'ActorByInternalName("rFoot")', replace the 'lFoot' and 'rFoot' with the internal names of the feet of your figure, and you're all set. Be sure to replace the lToe and rToe actor names too, they're also used in the V2 version.
My gallery   My freestuff
numanoid ( ) posted Tue, 10 February 2004 at 5:41 PM
Thanks. Your scripts are great. Thanks for the help.
svdl ( ) posted Tue, 10 February 2004 at 8:35 PM
Another tip: create props called rFoot and lFoot, move them to the balls of the feet of the character and parent them to the feet. Simple boxes or spheres work best. Then you can use the original script without modification on every possible figure!
numanoid ( ) posted Tue, 10 February 2004 at 10:06 PM
OK. I think I am going to rename the names on the actual model. Will let you know how it turns out. Don't forget to think about the four footed script. I have a work around for four footed animals, but it is cumbersome. I make props like you said and parent them to left front and right back, and get semi-decent results on the old script.
