Mon, Feb 3, 5:39 PM CST
Subject: How do I fix this Moonstone Prop?
Dizzie ( ) posted Tue, 10 February 2004 at 9:47 PM ยท edited Mon, 03 February 2025 at 5:34 PM
It's a prop in Free Stuff. I exported it as an obj and then ran it thru UV Mapper, but that didn't do any good. Thanks for the help!
Crescent ( ) posted Tue, 10 February 2004 at 10:21 PM
Did you try the Poser Grouping tool to select those polygons alone and flip the normals?
Dizzie ( ) posted Tue, 10 February 2004 at 11:25 PM
I selected the parts that have that black on it and then hit "Reverse Group Normals" but it made no difference...
ynsaen ( ) posted Tue, 10 February 2004 at 11:44 PM
They are degerenate or collinear facets -- I'd say degenerate most likely. There is a hot Key in UVMapper mapper for it but I don't recall right off the top of my head.
steveshanks ( ) posted Wed, 11 February 2004 at 7:52 AM
Its the insert key....if that doesn't fix it you can select the segments and split the vertices, it might spoil the smoothing though.....Steve
Dizzie ( ) posted Wed, 11 February 2004 at 5:03 PM
Geez, I don't know how to do all that plus I just have the UV Mapper freebie anyway....:>0
cooler ( ) posted Wed, 11 February 2004 at 5:17 PM
Dizzie, 1) open UV mapper classic 2) load Moonstone obj file 3) on the top toolbar select: edit---> tools---> Split Vertices 4) Save model with a new name, open it in poser & see if that fixes the problem. If so resave the obj file with the original name.
Dizzie ( ) posted Wed, 11 February 2004 at 5:45 PM
Cooler! You're an angel!!!!!!!!! It worked perfectly!! Amazing how easy and quick it is to fix something when you know what you are doing....thank you soooo much!!!!
