Sat, Feb 1, 4:39 PM CST
Forum Moderators: Staff
Subject: Turning Bends On/Off
Kalypso ( ) posted Wed, 11 February 2004 at 7:10 PM · edited Sun, 26 January 2025 at 11:12 AM
Site Admin
I wonder if anyone else has tried this for something. I'd like to be able to turn off the bends of certain body parts and tried to do that in a pose file but nothing seems to work. If I change bend 1 to bend 0 there is no effect. I've saved a cr2 with the bends I need switched off and compared to the original cr2 but cannot see where that information might be stored - any ideas?
numanoid ( ) posted Wed, 11 February 2004 at 7:30 PM
Where I have put the arrows is where you find the parameter. Change from 0 to 1 or other way to switch on or off. actor Floor_1:1 { name Floor_1 on >>>>>>> bend 0 dynamicsLock 1 collisionDetection 1 hidden 0 addToMenu 1 castsShadow 1 includeInDepthCue 1 parent BODY:1 channels
SAMS3D ( ) posted Thu, 12 February 2004 at 4:02 AM
or you can select the part, double click and the box comes up and un check it. Sharen
Kalypso ( ) posted Thu, 12 February 2004 at 4:14 AM
Site Admin
Sharen, that's what I do to turn bends off, problem is I want to make a pose file to do that automatically and store MAT information as well so I don't have to tell people to do that :) numanoid, I think that's the bend I'm making 0 as well. But it's not working, I'll try it again later - I'm not on my Poser machine right now - and let you know.
lesbentley ( ) posted Thu, 12 February 2004 at 3:14 PM
Kalypso, what you are doing should work from a pz2 (pose) file, but it's easy to get the syntax wrong or make a typo which stops the file from having an effect. We need to be clear what we are trying to do here. In Poser library files 'bend' has a technical meaning which is not necessarily what you might at first think. In Poser script 'bend' means that when a joint is rotated the "skin" round the joint stretches in an organic way. Here is an example of a pz2 to turn the 'bend' property off:
version
    number
actor abdomen
        bend 0
actor head
        bend 0
On the other hand in Poser script what we usually mean by "bend" in every day language is actually 'rotate?', where "?" is a place holder for X, Y, or Z. The easiest way to stop an actor from rotating is to set 'locked 1', the 'locked' line usually comes at or near the end of the actor block. A pz2 to implment this might look like so: { version { number }
actor abdomen
        locked 1
actor head
        locked 1
The problem with using 'locked 1' is that all the paramiters for that actor will be locked, target geom (morphs), scale, translate, the works, not just the rotations. Most of the time this will not matter, but if it does, the only alternative I can think of is to set the limits, but if you set the limits you will have to specify min and max values (which should be the same) in the pz2. In other words you have to specify the amount of rotation in the pz2, there is no way (that I can think of) to use a pose file to set limits for the current values of rotation as they exist in the doc.
numanoid ( ) posted Thu, 12 February 2004 at 6:26 PM
The bend that I marked with arrows is the bend you must turn off for non-organic objects, like a door or a mechanical joint.
