Mon, Jan 20, 1:33 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: UTC Runtime Error 6: overflow???
Aeneas ( ) posted Mon, 09 February 2004 at 1:41 PM · edited Sun, 05 January 2025 at 10:21 AM
I am trying to convert a body texture for V2 to V3 with the Universal Texture Converter. I downloaded the newest version (I have 1.0.12), set my preferences, but I et stuck on the last tab. I see no preview, and when I press "convert" I get a Runtime Error "6": overflow. The texture is a bit large (4000x4000 body), but that can hardly be a problem. My system: PIV 3GHz with HyperThreading 2 HDD od 40GB (loads of empty space) and 1,5GB DDRam. Never had such a problem with any other app, including P5. Can anyone point me at a solution? Thanks!
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
TrekkieGrrrl ( ) posted Mon, 09 February 2004 at 5:49 PM
Have a look and see if it really makes the new texture 4000x4000 - and not 4000x664625786879806 (something huge) I have seen that happen and it gives me that Overflow error. Not every time, but almost, if I forget to check output size :o/
Aeneas ( ) posted Tue, 10 February 2004 at 4:47 AM
Thanks. I will do that!
Aeneas ( ) posted Tue, 10 February 2004 at 5:13 AM
Thanks. Works like a charm now. I had to uncheck the "auto calculate output ratio", so I wonder why that checkbox is there. Over to South Africa to ask. (grin. long live the www!)
TrekkieGrrrl ( ) posted Tue, 10 February 2004 at 5:22 AM
yeah the auto-calculate seems a bit iffy :o9 But at least it's relatively easy to remedy, as long as you're aware of the problem. I'm glad you got it to work, it's an awesome program, isn't it? :o)
OReillyTX ( ) posted Tue, 10 February 2004 at 9:49 AM
The latest Version of UTC is v1.1.0 You can get the latest service release update from 3d universe site. The SR fixes UTC's quirkyness.
raven ( ) posted Sun, 15 February 2004 at 11:42 AM
You could also use UVMapper and the free .uvs files from DAZ to make a V3 capable of using V2 textures. That would also save hard drive space as you wouldn't need converted versions of your V2 textures.
