Tue, Feb 4, 4:14 AM CST
Subject: Poser 5 hair problem -- it stops at 174 hairs or so
Ethesis ( ) posted Tue, 17 February 2004 at 8:30 PM ยท edited Wed, 31 July 2024 at 6:37 PM
I needed some spikes and it occurred to me I could just grow hair. So, I set hair to 4 hairs and set out the limits and when I rendered ... 175 hairs -- way too many. It appears that Poser 5 has a hidden minimum number of hairs it will grow? Does anyone know a work around? The hair function is the perfect way to add spikes to things. Now, if hair could be made broad and flat, I could add blades to things as well as spikes. Thanks!
Little_Dragon ( ) posted Tue, 17 February 2004 at 9:45 PM
Yes, apparently there's an undocumented minimum-number-of-hairs. And no, no workaround. As a spikey alternative, have you considered using displacement instead? True, you'll have to paint a map telling Poser where to extrude each spike or blade, but if you have any familiarity with transmaps or bump maps, it isn't that difficult.
Ethesis ( ) posted Tue, 17 February 2004 at 11:29 PM
I've been involved with poser as an artist for about a month. I'm afraid maps and displacement are a little bit beyond me right now. The number is 174 or 175, now I'm wondering if that is per segment or for the whole figure. Ah well. Thanks!
