Wed, Oct 23, 10:34 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 4:45 pm)
Subject: Robotic looking figures??
kaposer ( ) posted Wed, 18 February 2004 at 12:10 PM · edited Wed, 23 October 2024 at 10:34 AM
A newbie question again, ive been trying to setup a figure with Poser5 using props, managing them (Dr Geep tut helped so much), and stablishing hierarchy. I made a working figure with all this, but...it look pretty organic:(, and what i had in mind was a robotic looking thing. Been trying to fix this stablishing polys groups for each bone with Group Editor but still goes wrong...Ive allready seen s bunch of mechanical looking figures so I know it is posible to do...just would know how. Thanx
MyFreestuff    My Store
weskaggs ( ) posted Wed, 18 February 2004 at 12:55 PM
It would definitely be easier to make sense of this question if you would show an image.
kaposer ( ) posted Wed, 18 February 2004 at 1:10 PM
Just find it by myselfs...if u dont want your body parts to have organic look..uncheck "bend" box in properties...:S Thanx anywayz weskaggs..i havent deleted this lame post cuz thought it may help some1...
mateo_sancarlos ( ) posted Wed, 18 February 2004 at 1:50 PM
S como no. Nunca utilice la funci del "bend" cuando estcreando las robustezas u otros "props" miles. Let us know how your robot develops.
maclean ( ) posted Wed, 18 February 2004 at 2:15 PM
kaposer, For all non-organic figures, always uncheck 'bend' for all body parts. If you edit your cr2s, you can maybe remove the Taper dial for all the body parts. It's a waste of space on most figures, although you might want to try it first and see what it does. I usually find it's useless. You can sometimes remove all the jointx, twisty, etc channels, plus the weld statements, but only if you have no use for arm/leg or other joint movements. If you interested in robo-humans, do a Google search for 'hajime sorayama'. He was a famous airbrush artist in the 70s and did the best ever robo-females. Nerd used to sell one for poser based on a sorayama design. mac
kaposer ( ) posted Wed, 18 February 2004 at 2:19 PM
Por supuesto mateo:)...cuando lo termine:S
kaposer ( ) posted Wed, 18 February 2004 at 2:22 PM
A good point maclean thank you for your help:)
xantor ( ) posted Wed, 18 February 2004 at 2:49 PM
You can delete the taper dial in the hierarchy editor, do show all parameters, find the taper select it and press delete, the same way as for deleting morphs.
maclean ( ) posted Wed, 18 February 2004 at 3:05 PM
Heh, xantor. Do you know that I didn't know you could do that? Just goes to show - you always learn something. Mind you, I do everything in cr2editor anyway, but for people who don't use it, that's a neat trick to remember. Thanks mac
xantor ( ) posted Wed, 18 February 2004 at 4:13 PM
It is a good way to delete stuff if you are unfamiliar about how cr2s are made up, you don`t want to delete the wrong things. You click on the name of the taper or the morph, just to make that clear.
