Mon, Nov 25, 11:39 AM CST
Subject: Need Sign With Changeable Letters-Help
Strixowl ( ) posted Sun, 22 February 2004 at 1:49 PM ยท edited Mon, 25 November 2024 at 11:35 AM
Need Sign With Changeable Letters-Help All shapes welcome :-) Thank you in advance
lesbentley ( ) posted Sun, 22 February 2004 at 2:12 PM
Could you be more specific. In most circumstances a texture map made in a paint progran and applied to a Poser square prop makes an acceptable sign.
lesbentley ( ) posted Sun, 22 February 2004 at 3:19 PM
In the above image both signs are a Poser square prop with a texture map applied to give the lettering, the top square is scaled down in the Y dimention, the bottom square uses a transparency map to make it circular. There are other ways you could make a changing sign, but it depends what you are using it for, and how you are using it. For instance is this for a static image or an animation? How many times does the sign need to change?
lesbentley ( ) posted Sun, 22 February 2004 at 4:37 PM
If the sign needs to change in an animation the following is one method to make a flat sign that can change to display 6 diffrent images on its front surface. 1. In Poser, load a Poser box prop. 2. Use the Group Editor to asign a difrent group to each facet of the box, name the facets 1, 2, 3, etc. Assign a diffrent material to each group, name the materials 1, 2, 3, etc. 3. Use the Hierachie Editor to convert the box into a figure. 4. apply a diffrent texture map with your desired wordings to each material of the new figure. 5. Z scale the BODY actor of the figure to 0.100%. 6. Resave the figure to a pallet. You can now selectivly show 4 of the facets by Y rotating the "box_1" body part of the figure in increments of 90 degrees, and you can show 2 more facets by X rotating box_1. The sign should be translated, scaled, and rotated via the Body actor NOT the box_1 body part. The box_1 actor should only be used to display the diffrent facets. Optionaly you can open the cr2 in a text editor and set the trackingScale for all 3 rotations of the box_1 actor to 90, and set 'hidden 1' for the taper, translation, and scale channels. This will make it easier to pose the sign correctly.
Strixowl ( ) posted Sun, 22 February 2004 at 5:09 PM
Thank you lesbentley I'll give some of these a go. It isn't for an animation Strixowl
Strixowl ( ) posted Sun, 22 February 2004 at 5:13 PM
Actually what I meant by changeable letters was: a sign that read anything,but I could change what it said to what I wanted it to say for a still pic.
Jackson ( ) posted Sun, 22 February 2004 at 5:26 PM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=5645
Here's one that might do what you want.
lesbentley ( ) posted Sun, 22 February 2004 at 6:39 PM
Glad to be of help, but I'm still not too sure of what sort of sign you want, after all there are a lot of diffrent kinds, street signs, parking signs, neon signs, pub signs, protest signs, office door signs, etc.
