Poser - OFFICIAL F.A.Q (Last Updated: 2026 Mar 08 8:23 pm)
I'm having the same problem. It is only in the firefly renderer and it is only with lights that I add. The default infinite light work fine. If I make the default infinite light spotlights the depth mapped shadows continue to work for those lights only. The depthmapped shadows continue to work in P5's P4 renderer. At least I'm not the only one seeing this. Thanks, Jeff
I cannot repeat this in either of of My P5 installs, and it's driving me nuts! Can you do a search in your Poser installation for shadow.tmp files and see if you have any that might be left over? Sr2 and earlier (and Sr3 with animations) tended to leave the files in place, and they interfere with the shadow map function in Sr4.
The tmp files to delete do not delete automatically and are "marked" so they will not be cleaned using most tools -- they have to be manually snagged. They usually reside in one of the folders in the Poser file itself, typically imageIOplugins or prefs. Shadow.tmp is only part of the file name, as well, and tmp is not the end extension (though I may be wrong there), but they can be found searching on that term
As already mentioned in another thread: I've had this shadow problem one time after installing sr4. I then switched between firefly/p4 renderer. Rendered. Turned shadows off/on/off. Changed "Dist End" settings to some value and back - and suddenly depthmap shadows in firefly worked. And until now there are no more problems. (Tested with a lot of other old scenes and new scenes) So my guess would be, that somewhere burried is a program flag which didn't get set correctly when updating and because of my "switching" I finally "activated" this flag. (From a programmers point of view this isn't so unusual.) But anyway, this is only wild guessing... ;-)
Ray traced shadows work fine. I don't have Depth shadows. Any hints out there? I reinstalled P5 to see if that would work, Nope, Nada, Zip. I didn't have to put my serial no. in, must not have deleted completely, any hints on that too. This is the only thing I have a problem with in sr4. I was trying to do a finished render, forgot how bad things look without shadows, makes me wonder why so many images in the gallery don't use them. I don't want the raytrace shadows. Thanks for any and all help
