This is very strange indeed, I also have these wings but don't have the problem of the textures mis-applying. I wonder if the MAT file got slightly corrupted or something? I'd suggest first re-installing the entire product, see if that helps. If not, there may be a reference error in the MAT file that you're using. You can open in Notepad or a similar text editor and check all the reference paths. It should be very easy to correct it and type in the correct texture and path, assuming that's the issue. You might also try contacting Sharkey via Instant Message here at Renderosity. It's my understanding that merchants are required to offer technical support when asked for it, but being human, they sometimes go on vacations, have ISP problems, or don't stop by here too frequently. :-) Best of luck, these wings really are spectacular.
Wouldn't MAT_UW and MAT_UV refer to different things (such as order of colors)? Why not try applying MAT_UW to both wings? I also wonder why you would have to apply 2 mats to one pair of wings. I really don't like MATs, and usually don't bother to install them, but simply load in the required texture in the Render > materials window. If I was using a MAT to apply wing color, I'd expect one MAT to operate across both wings. So why don't you try that? If all else fails... you can load the texture via the material window. carolly
Argon: That refers to the "outside" and "inside" of each wing, since bird feathers have different appearances depending on if you're viewing the inner or outer side. It doesn't help explain the problem you're having. There is a MAT_UW_Eagle and a MAT_UW_wEagle which could be confused at a quick glance. When you check the material editor, are both of those textures loaded perhaps? Carolly - "I also wonder why you would have to apply 2 mats to one pair of wings." Each wing is a separate model, so texture needs to be applied to each wing separately.
Richard Hazeltine, of the DAZ Forum Team, said:
I suspect you are suffering because you use Poser 5, which doesn't work well with partial MAT files, those that change only some of the settings. You may need to change the textures by hand, then use use Mat Pose Edit 3 to create new, Poser 5-friendly, MAT files.
About the courtesy to send the CR2's, could you send me the 2 wings with all the 4 MATs (MAT_UW_Eagle, MAT_UW_W Eagle, MAT_UW_White and MAT_UW_NoBump?
Can anyone give me some suggestion?
