Well, sorry to say Phil, no problems here. I think i said it once (or twice). 95% of the bugs sits... I defined a gel to a spot light. Then i edited the gel and attached first a jpg - no problem. Then a bmp - a brick texture. No problem as well. Then i switched to object space, then i made the texture (gel) scaling smaller. All without a problem. Maybe you send me the bmp you created so that i can test it here. I think you have my email address. see you, Walther
Maybe you could try to open the bmp file under MacOS (with photoshop or equivalent) and save it again in case it is coming from a PC with specific settings.
![file_101120.jpg](https://live.cdn.renderosity.com/forum/threads/1691363/file_101120.jpg)
Hi all, I'm having problems with VuePro (Version 267266 on MacOSX). VP keeps crashing while I try to apply an imagemap to a light gel. It's a .bmp... Can I use other image formats as well, since the manual doesn't say anything about the formats that can be used. Thanks, Phil P.S. I don't have the most current version of VP installed, because it doesn't support my Wacom anymore. :(
