Fri, Jan 24, 11:04 PM CST
Subject: Problems with editing lights gels in Vue Pro
TheWingedOne ( ) posted Thu, 04 March 2004 at 3:59 AM · edited Tue, 14 January 2025 at 7:14 PM
Hi all, I'm having problems with VuePro (Version 267266 on MacOSX). VP keeps crashing while I try to apply an imagemap to a light gel. It's a .bmp... Can I use other image formats as well, since the manual doesn't say anything about the formats that can be used. Thanks, Phil P.S. I don't have the most current version of VP installed, because it doesn't support my Wacom anymore. :(
TheWingedOne ( ) posted Thu, 04 March 2004 at 4:00 AM
...this is the error message I get, when I try to aplly the image map.
gebe ( ) posted Thu, 04 March 2004 at 4:05 AM
I'm on PC. There I have no problem to load any bitmap. First I have loaded an existing gel, then double-clicked the small gel icon. this opens the gel editor where I have loaded a bmp. Is this what you did Phil?
Then Walther may need to try it, as he is on a Mac too.
Guitta
TheWingedOne ( ) posted Thu, 04 March 2004 at 4:45 AM
Yes, Guitta. That's exactly what I did. I made the map in Photshop and saved it as a BMP as seen in my second post. Maybe Walther can reproduce this problem himself. ;) Thanks, Phil
gillbrooks ( ) posted Thu, 04 March 2004 at 8:16 AM
I had no problems loading one of Kromekats light gels and that was a .JPG file (I'm on PC) Gill
Gill
wabe ( ) posted Thu, 04 March 2004 at 8:16 AM
Well, sorry to say Phil, no problems here. I think i said it once (or twice). 95% of the bugs sits... I defined a gel to a spot light. Then i edited the gel and attached first a jpg - no problem. Then a bmp - a brick texture. No problem as well. Then i switched to object space, then i made the texture (gel) scaling smaller. All without a problem. Maybe you send me the bmp you created so that i can test it here. I think you have my email address. see you, Walther
agiel ( ) posted Thu, 04 March 2004 at 12:11 PM
Maybe you could try to open the bmp file under MacOS (with photoshop or equivalent) and save it again in case it is coming from a PC with specific settings.
TheWingedOne ( ) posted Fri, 05 March 2004 at 1:13 AM
Believe it or not. When I tried the map again yesterday evening it worked without crashing VuePro! Strange things happen sometimes. ;) Anyway, many thanks for your help!!! Phil
wabe ( ) posted Fri, 05 March 2004 at 1:28 AM
95% of the bugs sit where Phil? Good that it worked finally! I am really looking forward...
