Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 3:46 am)
I'd like to get rid of it, too. It's sped up Poser for me, but I, too, find that renders that used to be a piece of cake now quit on me. Dynamic hair seems to be a particular problem. And the shadow map problem is a real pain. I know, they're working on it, but in the mean time, what are we supposed to do? I tried editing the light names, but I guess my path names are still too long, because it didn't work. I can't believe they removed the previous SRs from their web site...
Now I feel really good. ;0) I downloaded SR4, but let it sit and waited for the onslaught of 'reviews'. And, boy, was it worth the wait. I haven't installed it yet, and won't until they make the SR for the SR (again). Makes one wonder how many testers are actually verifying the efficacy of their SRs before they go out the door...
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
 -- Bjarne
Stroustrup
And here I am, still happy as a lark, no slow downs on renders, overall speedup on everything. Given the resources available to them, kuroyume0161, I'd say they have about as many as they can handle. Which isn't enough to cover the incredibly broad range of system and software combinations available. but then again, there's only two or three dozen software companies in the world that have the resources to do that. I'm also paranoid about my system -- I have a burned copy of all the SR's for Poser 3 to the present. and it was ready in case SR4 tanked on me. Quite lucky, I guess...
:-P Nobody likes a gloater, y'know. ;-) I was really happy at first. It really did speed Poser 5 up amazingly. Then I noticed @#$% shadows. Or lack thereof. They can't have tested this very well. And they had a lot of nerve, telling us that the shadow map thing would only show up in certain unusual situations. I have Poser installed in the default directory - which I allowed it to do even though it's more of a pain for me, because I thought it would result in fewer problems - and I'm having the problem. Grrrr. I bet they never tested it with anything other than the default lighting.
sorry, hon -- really, wasn't trying to gloat... Of the five different systems I have P5 installed on at present, I don't have the shadow issue at all. And try as I might, I cannot duplicate it. IT's really bugging the hell out of me. The only thing I can guess is that a lot of the shadows trouble systems have newer graphics cards than any of my systems do (newest one in house right now is an older model Quadro in the renderbox, and after that it's strictly a Geforce2 level set. 'Cept the daughter's, who has a 4 fx, but I can't touch that box anymore unless it's to do an upgrade she's screwed up). I've got the parts for nearly everything else except the video and DDR RAM specs for the people I have gotten the info from. And on none of them have I been able to duplicate it.
Why would the video card make a difference? I thought the video card didn't matter to Poser. That's even weirder. From what the tech guy said, I thought anyone with a path name longer than X was having the problem. FWIW, I do have a semi-decent video card. I got what was the top of the line when I bought the computer in Nov. 2002. Radeon 9700 Pro with 128 Mb RAM. I have visions of playing DOOM 3 on this machine, never imagining the release was going to pushed past 2003. I'll probably have to buy a new video card to play it, the way it's been going...
path length! hadn't thought of that! Sheesh... Twisted -- do a search on SR4 Shadow here in the poser forum and go back over the last month. You'll find a few posts about it. off to change some paths....
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1687970
The link has a solution that has worked for some (but not for me), as well as links to previous discussions of the problem, including one in which a tech guy from CL weighed in with an explanation of sorts. They apparently reproduced the problem and figured out what was causing it fairly quickly once someone brought it to their attention.The problem is there are no depth map shadows. Ray trace shadows are fine, but there are no depth map shadows. You do have depth map shadows with the default lighting, but if you add a light, or use a new light set, the new lights won't have depth map shadows. CL says the problem happens if the path name (to where you installed Poser) is too long. They are working on a patch.
"CL says the problem happens if the path name (to where you installed Poser) is too long. They are working on a patch." speaking of weird...whats weird is how they figured out the long path name causes that. i mean....who would think that thats the problem? some programer discovered it by accident maybe? weird...
The thing is, a lot of people who are having trouble have Poser installed to the default path. Which, you have to admit, is pretty long. C:Program FilesMetacreations or Curious LabsPoser 5. (People who cut the company name out of the path don't seem to be having trouble.) So how can they have missed this?
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1690930
As for how they figured out what the problem was...it's not quite as random as it seems. They know what they "fixed," so they have a pretty good idea what they broke. :-) You know how Poser 5 has a habit of leaving shadow temp files in random places without deleting them? Well, SR4 was supposed to fix this. I have a feeling that this is what broke shadows in SR4. The link is to the thread where a tech guy from CL tries to explain what causes the problem.and yep. That's it. Finally duped it. Sheesh. Well, if this is so, then it's definitely not going to be a quick one. As randym77 pointed out, the fix to that damnable temp file issue is likely at fault, and that's likely tied into the fixed file location bug, so whatever they did has to be changed so that neither of the good parts are changed. Of course, they could always just have the darn thing default to C:Poser and move all yer files for ya... (j/k!!!)
I've been seriously wondering if I can just move my entire Poser folder up in the directory tree without breaking anything. Reinstalling would be such a pain. I'd have to remove Content Parasite again. I'd have to set all my preferences again. Not to mention I'd have to dig up my old serial numbers, since I started with P4...
As for how they figured out what the problem was...it's not quite as random as it seems. They know what they "fixed," so they have a pretty good idea what they broke. :-) [rant mode engaged] Which is precisely why they need to do SERIOUS QA testing before releasing these SRs. I would bet they are not regression testing it at all. That is to say they don't test the entire codebase once making a fairly impacting change (as with the shadows). If they had regression tested they would have noticed the new bug before it was ever released. As a software developer myself I cannot believe the number of bugs and problems they let go out the door. And we're talking about SRs here that are supposed to FIX things, not break 'em... [rant mode disengaged] ah, I feel better. Code I write goes through extensive testing at least :-) -gz-
Like as not, they did. The problem does not exist in a CuriousLabs default install (or at least, not as I have duplicated it), only in a metacreations default install (which, oddly enough, is not the default unless upgrading).
The problem is a little bit more complicated as the install path. The bug occurs when the "current working directory" has a long pathname. The reason not everyone has the problem is that the pathname of the "current working directory" depends on other programs currently running, previous programs started or maybe some other factor. As CL has mentioned before the problem has been identified and corrected and is now being tested to ensure that no other bugs are being introduced. That is what I have understood from what Curious Labs has said in previous messages
My default install path is to Curious Labs, not Metacreations, and I have the problem. My PZ3s are saved the root directory of the C drive, so that's not the problem. It's got to be the install path to Poser, which is C:Program FilesCurious LabsPoser 5. I'd have preferred just C:Poser, actually, but used the suggested path because I thought there would be less problems. Oh, the irony... I wonder if the use of multiple runtimes has something to do with it? That does add an extra layer, since it's another level down.
Well, I installed SR4 on my old system and my new system. An animation that would only render to 19 or so frames only rendered to 7 frames on both systems. The new system is a Pentium 4 3.2Ghz hyperthreading CPU w/ 2GB of memory. Different application installs on both computers. I never did render the animation w/ SR3 on my new system, 'cause SR4 came out when I was setting up my new one. I'm ready to roll back to SR3. IMO, SR4 was another step backwards.
As the subject line says...there should be a painless way to get rid of SR4. If they can't fix it, they should at least have an uninstall option. If they can't do that, at least put SR3 back up on their web site. Is that too much to ask? Hmmm. I just looked on their website, and it now lists SR 4.1. But the file looks like it's the same one. Are they about to update?
..that wouldn't surprise me quite honestly. Sad to say it has become the norm in the software industry as a whole. Rush release a product to market to recoup some of the investment and to pay the developers, then fix all the bugs after the fact. In this case we are getting patches to fix patches....which blows, big time.
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1708166
Sounds like other people are having, ahem, inconsistent results. I'm not sure if this is good news or bad news. On the one hand, it means I'm not crazy or completely incompetent. OTOH, it means they haven't gotten it quite right yet. :-PThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Because I think it's complete pants. I'm having renders quit on me all over the show and renders that should take a reasonable time are painfully slow. If it's improved anything, I'm not aware of it.
