Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Could be asking for the bum's most of the time they are in jpg format and you have to manually convert them.
Sandy
An imagination can create wonderful things
SndCastie's Little
Haven
I am attaching one of the error messages..
Victims...aren't we all?
Before you ask, YES my avatar is a portrait of me painted by someone very dear to me, so don't even think of using yourself ...mmmkay????
Visit my site for all of my art Digital Deviant
That is a body shape pose, not a texture pose. They require that you have the facial and body morph packages in addition to M3. If you don't have the body and face morph packs, that would explain all the errors. If you do have them, check to see that you installed them to the right place and didn't move them.
With the anime morph packs, I don't think the problem is not finding the morphs. Because the anime morphs work. But they don't seem to work very well. You get that error message, but the face does change. However, it doesn't look very good. I really wonder if they made some update to the geometry that screwed things up.
I have the body and face morph packs. I don't know what is wrong....What directory should they be in (sorry I am a bit of a Poser newbie!)
they should have installed to the right directories when you installed the exe from daz. write the message down that you copied or just keep this window open and see if they are in the folder it tells you it should be in. If not you might have moved it somewhere else and it is looking for it or you deleted the file. You could try reinstalling the exe again to see if that clears it up.
Sandy
SndCastie's Little
Haven
If you are using Poser 5, and if you installed to one of the non-default Runtimes (that is, not Poser 5Runtime ) then go to the Runtime you used, open it, open the Libraries folder, select the !DAZ folder and copy it; go to the Poser 5RuntimeLibraries folder and paste a copy of the !DAZ folder. That should help.
I HAD A PROBLEM WITH MICHEAL AND ORC PACK I BOUGHT AWHILE AGO. ALL I DID WAS GO TO DAZ WEBSITE AND WENT TO TECHNICAL HELP. GOT AN E-MAIL BACK THE NEXT DAY. THERE WAS AN EXTRA FILE LOADED IN THE WRONG PLACE. SORRY CAN'T REMEMBER EXACTLY WHAT AND WHERE. BUT IT DID THE TRICK. DAZ HAS A GREAT TEAM TO HELP US OUT WHEN WE (NEWBIES GO DUH?????). LUCK.
When I try to apply a MAT onto a figure in some cases (with Mike and Vic 3) I get all kinds of errors I have to click through saying something to the effect that it can't load the different face/body setting??? What could cause that and how can I fix it? Thanks for any help!
