Community Center F.A.Q (Last Updated: 2025 Feb 25 8:23 am)
Why not just print them out? There is a link there "Printer Friendly".... Personally I find it much easier to be able to read a piece of paper layed out in front of me as I follow along, than try to go back and forth between a program and the tut...on the screen.
I am, therefore I create.......
--- michelleamarante.com
Cheap cartridges screw up your printer -- don't use them. You could save the pages as HTML documents (use `save page' in the file menu), then you would not have to be online to read them. I do that sometimes with very long threads in the forums that I want to read through. Then you can open the docs at the same time as the application you're using, and cross-check that way (if you are using Windows, that is). m ;)
I have a canon prniter and use the cheap $9 inks ( thats $9 Canadian so like 12 cents USD or somehting) and I have never had a problem with my printer. Just throuwing in my 2 pennies (CAN) death :)
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Attached Link: http://www.pdf995.com/
I like to use PDF995 to "print" to a PDF file. You can pay for a license, or use it as adware that takes your web browser to an add page whenever you send something to it.You can also purchase ink cartridge refill kits..I know I usually buy one color cartridge, {$37.00 US, and one black cartridge $18.99 US} and also a refill kit {$20.00}..when the black cartridge runs out, I just keep refilling the color one..and if the nozzels get clogged, just use a cutip or paper towel with alcohol on it to wipe the nozzels off..let dry, and its all better...at least for a few more refills ;)
~Jani
Renderosity Community Admin
Has anyone thought of zip fileing the tutorials? Some times I have to read over thing 3 or 4 times; and still not get it. So I save the tutorials page by page. Haveing them in downloadable zip files would be nice.
