Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
I've used cameras with a field of view of 1 degree to get images with no vanishing points.
I just used the 200mm camera. As a side-note, the entire image all 3 map/models- were built as seperate models by me and co-worker James Hendricks over a two week period. When it came time to render, I thought that I would render them as seperate files and composite the results but after the third try I gave up because the perspectives never matched up. So I brought all 3 models into one file and rendered everything at once. We just got new computers last month (dual 2-ghz G5, 3 gigs of ram, fastest Radeon card they make for the Mac) so I figure, no problem. Wrong. This file brought my machine to it's knees. Moving objects around became a test of patience but rendering went okay.
I think the second CPU only helps out with rendering. Not with scene/model assembly.
For city blocks, I move my scenes around using binding-box mode. Not textured or rendered (or even line) mode.
![file_105430.jpg](https://live.cdn.renderosity.com/forum/threads/1741049/file_105430.jpg)
Well here it is. The original idea was scrapped, so I didn't finish the fully textured version. Modeled and rendered in Carrara.
